Sensor Updated and Sensor High Limit Updated log ASR9001
Fernando Galvao
I have an ASR9001 router and it is displaying these messages in monitoring. The odd about the TX power use cisco coaxial cables. I have amperage messages also in monitoring. The Router is connected with DC sources one in each rectifier. I already changed the rectifier and the message continues.
RP/0/RSP0/CPU0:GW-PE-CISCO#show controllers TenGigE0/0/2/0
Sun Oct 29 06:37:19.513 EST
Operational data for interface TenGigE0/0/2/0:
State:
Administrative state: enabled
Operational state: Up
LED state: Green On
Phy:
Media type: IEEE 802.3/802.3ae clause 30.2.5
Optics:
Vendor: CISCO-TYCO
Part number: 2163675-1
Serial number: TED1835T127
Wavelength: 0 nm
Digital Optical Monitoring:
Transceiver Temp: -1.000 C
Transceiver Voltage: 0.000 V
DOM alarms:
No alarms
Alarm Alarm Warning Warning Alarm
Thresholds High High Low Low
Transceiver Temp (C): 0.000 0.000 0.000 0.000
Transceiver Voltage (V): 0.000 0.000 0.000 0.000
Laser Bias (mA): 0.000 0.000 0.000 0.000
Transmit Power (mW): 0.000 0.000 0.000 0.000
Transmit Power (dBm): -inf -inf -inf -inf
Receive Power (mW): 0.000 0.000 0.000 0.000
Receive Power (dBm): -inf -inf -inf -inf
MAC address information:
Operational address: 4c5e.0c6a.1801
Burnt-in address: 0896.ad48.9ac8
No unicast addresses in filter
No multicast addresses in filter
Autonegotiation disabled.
Operational values:
Speed: 10Gbps
Duplex: Full Duplex
Flowcontrol: None
Loopback: None (or external)
MTU: 1518
MRU: 1518
Inter-packet gap: standard (12)
Logs:
Sensor Updated: voltage cisco-entity-sensor 172193 Module 0/RSP0/CPU0 - Voltage 0/RSP0/CPU0
  2017-10-29 00:35:04 System Sensor Updated: voltage cisco-entity-sensor 319242 Module 0/RSP0/CPU0 - Voltage 0/RSP0/CPU0
  2017-10-29 00:35:04 System Sensor Updated: voltage cisco-entity-sensor 320862 Module 0/RSP0/CPU0 - Voltage 0/RSP0/CPU0
  2017-10-29 00:35:04 System Sensor Updated: voltage cisco-entity-sensor 322450 Module 0/RSP0/CPU0 - Voltage 0/RSP0/CPU0
  2017-10-29 00:35:04 System Sensor High Limit Updated: dbm cisco-entity-sensor 18995616 module mau 0/0/2/3 - power Tx 0/0/2/3 (NAN)
  2017-10-29 00:35:04 System Sensor Low Limit Updated: dbm cisco-entity-sensor 18995616 module mau 0/0/2/3 - power Tx 0/0/2/3 (NAN)
  2017-10-29 00:35:04 System Sensor High Limit Updated: dbm cisco-entity-sensor 29234194 module mau 0/0/2/1 - power Tx 0/0/2/1 (NAN)
0 Replies 0
