10-31-2006 06:16 AM - edited 03-03-2019 02:31 PM
I would like to connect a Cisco2621 with a Nortel ASN Router over a V.35 serial line. Are there parameters on the Cisco or the Nortel side that I have to configure for a good functionality.
10-31-2006 06:23 AM
Kurt
I have not done this so can not speak from any personal experience. But the parameter that comes to mind first is the encapsulation. The default encapsulation on Cisco is HDLC and their implementation is somewhat proprietary. It may interoperate with other vendors but might not. You would be much safer to specify PPP (or something like Frame Relay).
Rick
10-31-2006 07:15 AM
In order for the two beasts to talk to each other, you need to set them both for PPP encapsulation. All other parameters are fine...
