10-20-2009 08:41 PM - edited 03-04-2019 06:26 AM
e1 link is fluctuating , what can be the issue
Router#sh int serial 0/3/0:0
Serial0/3/0:0 is down, line protocol is down
Hardware is GT96K Serial
Description: "Router"
Internet address is 10.100.1.58/30
MTU 1500 bytes, BW 1984 Kbit, DLY 20000 usec,
reliability 163/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP Closed, loopback not set
Keepalive set (10 sec)
Last input 00:00:48, output 00:00:38, output hang never
Last clearing of "show interface" counters 29w6d
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/5/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1488 kilobits/sec
5113915 packets input, 582233138 bytes, 0 no buffer
Received 0 broadcasts, 9 runts, 8904 giants, 0 throttles
1888935 input errors, 1888927 CRC, 1225559 frame, 110516 overrun, 0 ignored
, 507633 abort
7532290 packets output, 1034655047 bytes, 0 underruns
0 output errors, 0 collisions, 19 interface resets
4321 carrier transitions
Timeslot(s) Used:1-31, SCC: 0, Transmitter delay is 0 flags
10-20-2009 10:00 PM
Circuit failure, even if telco claims otherwise.
10-20-2009 11:06 PM
thank you very much, any document relating troubleshooting links,
any idea of Telco link -Circuit failure Trouble shooting
10-21-2009 02:44 AM
Let telco do their work. When fixed, it will start working again.
