Serial Interface: Clock Rate bandwidth
Kaushik Ray
Hello
I would be grateful if someone can advice me on this:
I have a WAN link with capacity of 2560Kbps. I was looking at Solarwinds for the interface and see that the interface is capped at 2Mbps. While checking through the interface I see that the Serial interface is configured as follows:
interface Serial0/1/0
bandwidth 2560
no ip address
load-interval 30
no fair-queue
clock rate 2000000
end
Could the clock rate set as 2000000 be capping the bandwidth? I wanted to change it and the next available clockrate is
4000000; should i then set it to this value?
Then just use an ethernet connection.
21 Replies 21
Jan Hrnko
Level 4
Level 4
Well, clock rate command does not limit the speed of the link, it sets it. I suppose that the interface will not work properly with 4Mbps clock settings and I am not sure if it even allows you to set it that high.
As for bandwidth command, it is there for other purposes, not for setting the speed of the link - as you certainly know.
Best regards,
Jan
Jan
thanks for your reply.
I checked the other Serial interface which is in a down state and could put the 4Mbps in it. But if you think it would not work properly with the 4Mbps clock settings what do you suggest putting in for me to be able to allow the whole 2560Kbps?
thanks
Here are the two interfaces for the WIC-2T the first one is the live one and second one is in down state.
Router#sh run int s 0/1/0
Building configuration...
Current configuration : 237 bytes
bandwidth 2560
no ip address
load-interval 30
no fair-queue
clock rate 2000000
end
Router#sh run int s 0/1/1
Current configuration : 74 bytes
interface Serial0/1/1
no ip address
shutdown
clock rate 4000000
end
When I tried to put a clock rate of 2560000 it did not accept
Router(config)#int s 0/1/1
Router(config-if)#clock rate 2560000
clock rate 2560000 is not supported
Unluckily, I am not near any real device and lab is not sufficient. However, I do remember that in some versions of IOS, you could set the clock rate higher than actual bandwidth that your device can provide.
I found this statement from one of the members of CSC,fsebera:
Cisco IOS/Serial hardware  will dynamically clock to the highest level the hardware supports if you  select a clock rate higher than the actual hardware interface rate.
That would be worth testing. I mean, if it works properly on your hardware and with your IOS. May I kindly ask you, which version of IOS do you use?
Best regards,
Jan
Hi Jan thanks for your reply:
the IOS version on the router is c2800nm-advipservicesk9-mz.124-22.T5.bin
I tried to change the clock rate to 4000000 but I saw the traffic starting to reduce which is when I reverted back to the 2000000 but it goes back to being capped on the 2Mbps.
Is there any way round it?
When i set the clockrate to 4000000, the next available clock rate more than 2560Kbps the traffic goes down as shown below. Did a shut / no shut on the interface and kept it for 5 minutes but still the input rate stays low: as soon as I put the clock rate back to 2000000, in 90 secs it goes back to 1.8Mbps.
Router#sh int s 0/1/0
Serial0/1/0 is up, line protocol is up
  Hardware is GT96K Serial
  MTU 1500 bytes, BW 2560 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 55/255, rxload 86/255
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  CRC checking enabled
  Last input never, output 00:00:31, output hang never
  Last clearing of "show interface" counters 00:05:27
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 865000 bits/sec, 397 packets/sec
  30 second output rate 560000 bits/sec, 457 packets/sec
     116608 packets input, 36336001 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     125447 packets output, 19471391 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Router(config)#int s 0/1/0
Router(config-if)#clock rate 2000000
     reliability 255/255, txload 54/255, rxload 182/255
  Last input never, output 00:00:14, output hang never
  Last clearing of "show interface" counters 00:07:10
  30 second input rate 1834000 bits/sec, 563 packets/sec
  30 second output rate 549000 bits/sec, 540 packets/sec
     171380 packets input, 58179819 bytes, 0 no buffer
     179102 packets output, 26116335 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Router#
Is there any way to overcome this?
No.
Thanks Paolo for your response; i was thinking changing the WIC-2T to HWIC-2T / 4T; this could help?
regards
Kaushik
No. What are you trying to do ?
There is a our router and a client router back to back and the traffic is getting upto a max of 2Mbps as the clockrate is 2000000 on the DCE side (which is our Router). but the total capacity of the WAN link is 2560Kbps. When i change the clock to the next available rate which is 4000000, the traffic passing is starting to go down. when i revert back the clock rate to 2000000 it goes back upto the max 2Mbps again but not beyond that.
Ask telco to give you an ethernet interface that uses the full link capacity.
Thanks Paolo for the response but actually the connection is back to back to the client router in the same rack there is no telco in between.
