Serial over IP
c.captari
Hi.
Having 2 windows computers with hyperterminal (in real life i have 2 non ip devices with rs232, 19200 bps, flow control: none, stop bits 1. For the purpose of test i'll use hyperterm) and 2 cisco routers 2811. Each workstation terminates a serial cable in one 2811.
Can someone recommend a technology to make the 2 hyperterminals talk serially over IP.
I was looking for other ideas apart from SLIP . I think it's possible to encapsulate that into PPP as well, but can't find much documentation.
Basically i'm looking for documentation on a technology that would transparently encapsulate this serial conversation over IP.
paolo bevilacqua
Hi, this is asynch transport and is done routinely with cisco routers. See:
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t5/feature/guide/asyncudp.html
7 Replies 7
Giuseppe Larosa
Hello Claudiu,
I would consider L2tPv3 and DLSW+.
for L2tpv3
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html#wp1043078
for DLSW+
http://www.cisco.com/en/US/docs/ios/11_3/ibm/configuration/guide/bcdlsw.html#wp2144
but I have doubts they can support Rs-232: L2tp3 can transport PPP frames.
I tried to search and I've found some third party devices
http://www.connectivity.avocent.com/products/network-based/
ESP-2 MI Serial Hub
or SW based see
http://www.taltech.com/products/tcpcom.html
using a PC
I remember another thread mentioning a standard for this kind of transport.
Hope to help
Giuseppe
paolo bevilacqua
Hello Paolo,
I didn't know this feature it is the right tool for his needs
Best Regards
Giuseppe
Yes. Nothing else works for async.
Hi. Thanks for the sugestion
Indeed this seems to do the job.
With the only drawback that is unreliable being on top of UDP. I would have prefered a TCP solution.
You can do it over tcp too. Just have a telnet autocommand to the "raw port", that is 2000 + line number. Basically one router is active, the other waits for the connection.
People used that for years before the feature I posted the link about.
drot389
I know the solution to work with serial port over IP network - the software http://www.eltima.com/serial-over-ip/. I use it to access serial devices connected to PC.
