Serial Speeds
alsayed
i have to know the speed of the various serial interface for all speed and connection that use with cisco product
10xs
Hi Ali,
We call T1/E1 interface as "T1, E1, and G.703 Multiflex Trunk Voice and WAN Interface Cards"
WIC1T/2T support upto 2Mbps on each port.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b8b.html
With NM,It depends which NM module you are using with the WAN interface card on it. Please see the diff NM's and the WAN cards you can put in the NM slots.
http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html
-amit singh
6 Replies 6
Danilo Dy
Not sure if I got everything, here are the serial that I use and know;
T1 = 1.544 Mbps
E1 = 2.048 Mbps
T3 = 45 Mbps
E3 = 34 Mbps
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_white_paper09186a0080091d4b.shtml
10xs for ur reply;i mean what is the name of interface that run:
T1 = 1.544 Mbps
E1 = 2.048 Mbps
T3 = 45 Mbps
E3 = 34 Mbps
WIC 1T/2T
NM????
10XS FOR UR INFO
here you can have all information of all types of interface and modules:
http://www.cisco.com/en/US/products/hw/modules/prod_module_category_home.html
ali i will reply to your mail today evening...
regards
Devang
Hello Devang 10xs for ur reply
Hi Ali,
-amit singh
HI amit singh!
Thanks a lot for ur reply
