Server Teaming
nasheer.ahmad
I am having two 3750 L3 switches which are configured in HSRP.
On 1 Vlan all my servers are conencted.For teaming and HA of servers I had connected another switch,assigning same VLAN and connected to the other giga port in 3750.
Is there any configuration need to be done for load sharing.
regds
Nasheer
Edison Ortiz
You mentioned you've attached both switches via their GigaBit switchports not via the stack, therefore - you can't configure etherchanneling on the switch side which would give you the load-sharing services.
Etherchanneling requires both switches to be stacked, once they are stacked, they both behave as a single hardware device.
