Service Instance forward LACP protocol on ASR router
9813108aa
Hello All,
I try to create etherchannel between SW1 and SW2 with service instance on CSR,
but it not working for etherchannel , How can I solve this problem,
follow please
CSR
interface GigabitEthernet1
no ip address
negotiation auto
no mop enabled
no mop sysid
service instance 1 ethernet
encapsulation untagged
l2protocol peer lacp
service instance 10 ethernet
encapsulation dot1q 10
interface GigabitEthernet2
no ip address
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet3
no ip address
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet4
no ip address
negotiation auto
no mop enabled
no mop sysid
SW1&SW2
interface Ethernet0/0
switchport mode trunk
channel-group 1 mode active
end
interface Ethernet0/1
end
Thanks in advance,
Vincent
how are the port channel interfaces configured ? Post the full configs of the CSR (ASR?) and both switches...
Hello
This is port channel configuration
and have no port channel on CSR , ony Switch
SW1&SW2
interface Port-channel1
end
balaji.bandi
As i remember last time i testd on PNET /EVE - EVC not worked, only worked for IOS-XR
worth looking below document :
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/ios-xml/ios/cether/configuration/xe-16-7/ce-xe-16-7-book/ce-ether-vc-infra-xe.html.xml
BB
