Service name tag ignored with PPPOE
Ken Wold
I have a c3745 setup up as a PPPOE server for testing. The problem is the c3745 is accepting any service name tags.
In my case, I want to have the client use the following attributes:
username: local
password: local
service name: test
In my tests, I set up a negative test where the client sends foobar as a service name. I would like the router to deny the PPPOE connection attempt because the service name is incorrect or does not exist. Instead, the c3745 accepts the service name of foobar in the PADI and echos the service name foobar back in the PADO.
Not sure how to configure the c3745 to deny connections based on service tag. Any help would be appreciated!
Here is the config:
version 12.4
service config
hostname c3745
boot-start-marker
boot-end-marker
enable secret 5 $1$J70H$cHLxuWuGLAM7GwS/Oz45R1
aaa new-model
aaa authorization network default local
aaa session-id common
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.0.0 172.16.98.255
ip dhcp excluded-address 172.16.100.0 172.16.255.255
ip dhcp pool pppoe
   network 172.16.99.0 255.255.255.0
   default-router 172.16.0.20
   dns-server 12.127.16.67 12.127.16.68
   domain-name quijibozen.com
ip domain name quijibozen.com
ip name-server 12.127.16.68
ip name-server 12.127.16.67
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vpdn enable
vpdn-group 1
! Default L2TP VPDN group
! Default PPTP VPDN group
accept-dialin
  protocol any
  virtual-template 1
local name fudge
username admin privilege 15 secret 5 $1$14OU$iJcsUWd.HEYRWi/tqu1AC/
username cisco secret 5 $1$z6B1$XF6VSpN16hv7.J.3Fpr2r1
username local secret 5 $1$E2FX$.AyToxxNawuXQHAhVqYGr.
bba-group pppoe global
interface FastEthernet0/0
ip address 172.16.0.20 255.255.0.0
speed 100
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Virtual-Template1
description PPPOE
ip unnumbered FastEthernet0/0
peer default ip address dhcp-pool pppoe
ppp authentication pap chap
ppp accounting pppoe
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.0.1
ip http server
no ip http secure-server
control-plane
line con 0
logging synchronous
speed 115200
line aux 0
line vty 0 4
logging synchronous
transport input none
line vty 5 15
logging synchronous
Cisco IOS Software, 3700 Software (C3745-ADVENTERPRISEK9-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 08:18 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
c3745 uptime is 11 minutes
System returned to ROM by reload
System image file is "flash:c3745-adventerprisek9-mz.124-25d.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 3745 (R7000) processor (revision 2.0) with 243712K/18432K bytes of memory.
Processor board ID JMX0838L2SU
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
Configuration register is 0x3922
debug output:
Mar  2 04:44:31.831: ppp2 PPP: Send Message[Dynamic Bind Response]
*Mar  2 04:44:31.831: ppp2 PPP: Using vpn set call direction
*Mar  2 04:44:31.831: ppp2 PPP: Treating connection as a callin
*Mar  2 04:44:31.831: ppp2 PPP: Session handle[14000003] Session id[2]
*Mar  2 04:44:31.831: ppp2 PPP: Phase is ESTABLISHING, Passive Open
*Mar  2 04:44:31.831: ppp2 LCP: State is Listen
*Mar  2 04:44:32.823: ppp2 LCP: I CONFREQ [Listen] id 138 len 10
*Mar  2 04:44:32.823: ppp2 LCP:    MagicNumber 0x0EC26814 (0x05060EC26814)
*Mar  2 04:44:32.823: ppp2 LCP: O CONFREQ [Listen] id 1 len 18
*Mar  2 04:44:32.823: ppp2 LCP:    MRU 1492 (0x010405D4)
*Mar  2 04:44:32.823: ppp2 LCP:    AuthProto PAP (0x0304C023)
*Mar  2 04:44:32.823: ppp2 LCP:    MagicNumber 0x12037372 (0x050612037372)
*Mar  2 04:44:32.823: ppp2 LCP: O CONFACK [Listen] id 138 len 10
*Mar  2 04:44:32.823: ppp2 LCP: I CONFACK [ACKsent] id 1 len 18
c3745#Mar  2 04:44:32.823: ppp2 LCP:    MRU 1492 (0x010405D4)
*Mar  2 04:44:32.823: ppp2 LCP: State is Open
*Mar  2 04:44:32.823: ppp2 PPP: Phase is AUTHENTICATING, by this end
*Mar  2 04:44:32.823: ppp2 PAP: I AUTH-REQ id 11 len 16 from "cisco"
*Mar  2 04:44:32.823: ppp2 PAP: Authenticating peer cisco
*Mar  2 04:44:32.823: ppp2 PPP: Phase is FORWARDING, Attempting Forward
*Mar  2 04:44:32.823: ppp2 PPP: Phase is AUTHENTICATING, Unauthenticated User
*Mar  2 04:44:32.831: ppp2 PPP: Phase is FORWARDING, Attempting Forward
*Mar  2 04:44:32.831: ppp2 PPP: Send Message[Connect Local]
*Mar  2 04:44:32.831: ppp2 PPP: Bind to [Virtual-Access1.1]
*Mar  2 04:44:32.831: Vi1.1 PPP: Send Message[Static Bind Response]
*Mar  2 04:44:32.831: Vi1.1 PPP: Phase is AUTHENTICATING, Authenticated User
*Mar  2 04:44:32.831: Vi1.1 PAP: O AUTH-ACK id 11 len 5
*Mar
c3745#2 04:44:32.831: Vi1.1 PPP: Phase is UP
*Mar  2 04:44:32.831: Vi1.1 IPCP: O CONFREQ [Closed] id 1 len 10
*Mar  2 04:44:32.831: Vi1.1 IPCP:    Address 172.16.0.20 (0x0306AC100014)
*Mar  2 04:44:32.831: Vi1.1 PPP: Process pending ncp packets
*Mar  2 04:44:32.835: Vi1.1 IPCP: I CONFREQ [REQsent] id 37 len 22
*Mar  2 04:44:32.835: Vi1.1 IPCP:    Address 0.0.0.1 (0x030600000001)
*Mar  2 04:44:32.835: Vi1.1 IPCP:    PrimaryDNS 0.0.0.0 (0x810600000000)
*Mar  2 04:44:32.835: Vi1.1 IPCP:    SecondaryDNS 0.0.0.0 (0x830600000000)
*Mar  2 04:44:32.835: Vi1.1 AAA/AUTHOR/IPCP: Start.  Her address 0.0.0.1, we want 0.0.0.0
*Mar  2 04:44:32.835: Vi1.1 AAA/AUTHOR/IPCP: Reject 0.0.0.1, using 0.0.0.0
*Mar  2 04:44:32.835: Vi1.1 AAA/AUTHOR/IPCP: Done.  Her address 0.0.0.1, we want 0.0.0.0
*Mar  2 04:44:34.835: Vi1.1 IPCP: O CONFNAK [REQsent] id 37 len 22
*Mar  2 04:44:34.835: Vi1.1 IPCP:    Address 172.16.99.1 (0x0306AC106301)
*Mar  2 04:44:34.835: Vi1.1 IPCP:    PrimaryDNS 172.16.0.7 (0x8106A
c3745#
%Error opening tftp://172.16.0.7/network-confg (Timed out)C100007)
*Mar  2 04:44:34.835: Vi1.1 IPCP:    SecondaryDNS 12.127.16.67 (0x83060C7F1043)
*Mar  2 04:44:34.835: Vi1.1 IPCP: I CONFACK [REQsent] id 1 len 10
*Mar  2 04:44:34.835: Vi1.1 IPCP:    Address 172.16.0.20 (0x0306AC100014)
*Mar  2 04:44:34.835: Vi1.1 IPCP: I CONFREQ [ACKrcvd] id 39 len 22
*Mar  2 04:44:34.835: Vi1.1 IPCP:    Address 0.0.0.1 (0x030600000001)
*Mar  2 04:44:34.835: Vi1.1 IPCP:    PrimaryDNS 0.0.0.0 (0x810600000000)
*Mar  2 04:44:34.835: Vi1.1 IPCP:    SecondaryDNS 0.0.0.0 (0x830600000000)
*Mar  2 04:44:34.835: Vi1.1 IPCP: O CONFNAK [ACKrcvd] id 39 len 22
*Mar  2 04:44:34.835: Vi1.1 IPCP:    PrimaryDNS 172.16.0.7 (0x8106AC100007)
*Mar  2 04:44:34.835: Vi1.1 IPCP: I CONFREQ [ACKrcvd] id 40 len 22
c3745#    PrimaryDNS 172.16.0.7 (0x8106AC100007)
*Mar  2 04:44:34.835: Vi1.1 IPCP: O CONFACK [ACKrcvd] id 40 len 22
*Mar  2 04:44:34.835: Vi1.1 IPCP: State is Open
*Mar  2 04:44:34.835: Vi1.1 IPCP: Install route to 172.16.99.1
and more debug output
*Mar  2 04:53:24.295: PPPoE 0: I PADI  R:001f.f342.81fc L:ffff.ffff.ffff Fa0/0
FF FF FF FF FF FF 00 1F F3 42 81 FC 88 63 11 09
00 00 00 12 01 01 00 06 66 6F 6F 62 61 72 01 03 ...
*Mar  2 04:53:24.295: PPPoE 0: O PADO, R:0012.0007.f700 L:001f.f342.81fc Fa0/0
*Mar  2 04:53:24.295:  Service tag: foobar
00 1F F3 42 81 FC 00 12 00 07 F7 00 88 63 11 07
00 00 00 2F 01 01 00 06 66 6F 6F 62 61 72 01 03 ...
*Mar  2 04:53:24.299: PPPoE 0: I PADR  R:001f.f342.81fc L:0012.0007.f700 Fa0/0
00 12 00 07 F7 00 00 1F F3 42 81 FC 88 63 11 19
00 00 00 26 01 01 00 06 66 6F 6F 62 61 72 01 04 ...
*Mar  2 04:53:24.299: [3]PPPoE 2: O PADS  R:001f.f342.81fc L:0012.0007.f700 Fa0/0
c3745#
00 1F F3 42 81 FC 00 12 00 07 F7 00 88 63 11 65
00 02 00 26 01 01 00 06 66 6F 6F 62 61 72 01 04 ...
Ken Wold
Bump!
