12-04-2010 01:37 AM - edited 03-04-2019 10:40 AM
may i know which is the fastest speed & way to transfer the IOS file into cisco 870 series router with blank IOS file at memory.
thanks.
12-04-2010 02:08 AM
You can use Xmodem, Ymodem, and the Zmodem.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
hth
Muammer
12-04-2010 04:41 AM
In additon to what muammer said and good link. you can can increase speed if you want to to copy IOS when you are in
rommon mode of router is console baud rate.
change console baud rate? y/n [n]: y
enter rate: 0 = 9600, 1 = 4800, 2 = 1200, 3 = 2400
4 = 19200, 5 = 38400, 6 = 57600, 7 = 115200 [0]: 7
change the boot characteristics? y/n [n]:
Choose above option of 115200 which ensure ios will be copied at max. spped because default is 9600.
Hope this helps
Mahesh
12-04-2010 07:46 AM
Use tftpdnld from rommon.
Fast and easy transfer via ethernet.
