11-07-2011 12:14 PM - edited 03-04-2019 02:11 PM
i have configured shaping on a interface for 37.6Mbp, while the interface NOT congested and the traffic rate is no more then 5Mbps i'm getting a drop rate and the total drops queue counter is raising.
Class-map: class-default (match-any)
2157924144 packets, 2458512117027 bytes
30 second offered rate 3802000 bps, drop rate 3000 bps
Match: any
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/41/0
(pkts output/bytes output) 94465/86278499
QoS Set
dscp cs3
Packets marked 2157806370
shape (average) cir 37600000, bc 150400, be 150400
target shape rate 37600000
2162832613 packets, 2463933631868 bytes
30 second offered rate 2654000 bps, drop rate 2000 bps
Match: any
Queueing
(queue depth/total drops/no-buffer drops) 0/4051/0
(pkts output/bytes output) 4998926/5514847240
QoS Set
dscp cs3
Packets marked 2162714137
any reason for that?
why do i get packet drop in this case?
11-08-2011 12:01 AM
Size of you queue is 64 packets only.
Increase the queue size.
HTH,
Smitesh
11-08-2011 02:34 AM
for your CIR you've choosed too small BC/BE values.
I'd suggest to increase to BC/BE value to 7050000/14100000
11-08-2011 04:00 AM
Have you manually tuned the Bc and Be?. Normally its recommended to leave the values as is as Cisco would by default calculate those values. I am not saying you cant tune them but you have to be very cautious about tuning them and you need to know the exact traffic requirements
It would be good if you just use the below and not add any burst values
class class-default
shape average 37600000
When i added this on a 7200/3630 platform I get the below Bc and Be values
6#sh policy-map interface gigabitEthernet 1/0 output
GigabitEthernet1/0
Service-policy output: TEST
52 packets, 5168 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
37600000/37600000 235000 940000 940000 25 117500
so as u can see the Bc=94000 and Be=94000. But in your case they seem to be too low.
Kishore
