Serving two hosts through port 443 SSL
Frank27
This is the scenario :
A  1941 router  needs to redirect port 443(SSL) to a web server inside the LAN port 3000 while another web server needs to be served on port 443-443 :
router 1941 ----> outside 443 inside 443
        =         ----> outside 443 inside 3000
Is this possible without changing the outside port?
@Georg Pauwen wrote:
@paul driver I guess I am misreading the original post. Where would the outside2 come from ? Are you suggesting to get an additional ISP connection, or an additional public IP address from the existing ISP ?
Yes the latter, use an addtional inside global ip or use a different outside tcp port.
Kind Regards
Paul
18 Replies 18
Frank27
i found that the only solution is changing the outside port...
if different IP you use for each NAT then it OK but same IP I don't think so.
balaji.bandi
No, you can do that instead use a different port
ip nat inside source static tcp x.x.x.x 443 y.y.y.y 443
ip nat inside source static tcp x.x.x.x 8443 z.z.z.z  3000
Another way is FQDN.
BB
@balaji.bandi
just out of curiosity, which device and IOS did you get this to work on ? Same outside address and same outside port, but different inside ports ? I get an error saying that the IP is already mapped...
any router does this work - I would suggest checking the syntax correctly before configuring ( sure 'miss-configuration' get that error)
BB
@balaji.bandi I think OP is asking the question because he wants to map both servers to the SAME outside IP address, not different ones.
Otherwise I guess he would not be asking the question to start out with...
I do address OP's question and asked to use different methods, just for clarity here.
BB
@balaji.bandi
As I understood the question, it was if the below works:
ip nat inside source static tcp 192.168.1.10 443 212.12.10.243 443
ip nat inside source static tcp 192.168.1.11 3000 212.12.10.243 443
It doesn't work. I thought you got it to work, maybe on a different IOS version, that's why I was asking.
yes by changing the inside global address as stated by @balaji.bandi
Options I would say are:
router 1941 ----> outside1 443 inside1 443
        =         ----> outside1 3000 inside2 443
        =         ----> outside2 443 inside2 443
kind regards
Paul
Kind Regards
Paul
Kind Regards
Paul
Frank27
Yes , sorry i need to add some clarifications :
1) There is one static public ip in the WAN -- not two.
2) the LAN IPs are different but the scope of this question was doing it without mapping different external port
to recap :
x.x.x.x (Static public)--> 192.168.0.1 (webserver running CentOS)---> ext 443 int 443
                                --> 192.168.0.2 (wevserver running CentOS)---> ext 443 int 3000
this was the deal.. i make it work using a different external port for the second address like:
x.x.x.x (Static public)--> 192.168.0.1 (webserver running CentOS)---> ext 5000 int 443
yes that is what our suggestion.
or use FQDN.
BB
@balaji.bandi What would an FQDN-based solution look like with regard to this specific issue ?
