set command on router be slow after NAT
rezamira
Hi dear friends
i have a question about a strange happen
i have an ASR1006-X, this router has one port-channel interface (20Gbps) that about 1Gbps traffics comes from inside, in this router, i have 5 ACLs for matching traffic, and 5 nat pools for translating packets, after 1 day, login to router will be very slow, whereas cpu process is less than 5%, memory is less than 25% and so on, everything about resources is good but typing in router is very slow (like as connecting to router over DS0 link)
about 45K NAT be exist in X-late table in peak time
given that, ping time of router in peak time in less than 1ms. u
would you help me plz? if you need any output command, i can send for you
regards
Reza
when set terminal monitor on router, consecutively output comes, this output no stop
*Mar 22 09:31:24.691: %IOSXE-6-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:080 TS:00002348029991920041 %NAT-6-LOG_TRANSLATION: Created Translation TCP 192.168.2.64:53759 172.28.127.72:53759 89.55.4.221:445 89.55.4.221:445 0
*Mar 22 09:31:24.693: %IOSXE-6-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:073 TS:00002348029993991618 %NAT-6-LOG_TRANSLATION: Created Translation TCP 192.168.60.219:50320 172.28.127.6:50320 43.212.175.197:445 43.212.175.197:445 0
*Mar 22 09:31:24.693: %IOSXE-6-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:123 TS:00002348029994401633 %NAT-6-LOG_TRANSLATION: Created Translation TCP 192.168.2.64:53760 172.28.127.72:53760 110.254.97.254:445 110.254.97.254:445 0
*Mar 22 09:31:24.693: %IOSXE-6-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:158 TS:00002348029994514543 %NAT-6-LOG_TRANSLATION: Created Translation TCP 192.168.2.64:53766 172.28.127.72:53766 128.15.252.72:445 128.15.252.72:445 0
*Mar 22 09:31:24.693: %IOSXE-6-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:145 TS:00002348029994628531 %NAT-6-LOG_TRANSLATION: Created Translation TCP 192.168.2.64:53773 172.28.127.72:53773 15.191.20.216:445 15.191.20.216:445 0
*Mar 22 09:31:24.694: %IOSXE-6-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:057 TS:00002348029994742506 %NAT-6-LOG_TRANSLATION: Created Translation TCP 192.168.2.64:53775 172.28.127.72:53775 170.69.136.189:445 170.69.136.189:445 0
*Mar 22 09:31:24.694: %IOSXE-6-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:107 TS:00002348029994858556 %NAT-6-LOG_TRANSLATION: Created Translation TCP 192.168.2.64:53796 172.28.127.72:53796 215.175.207.239:445 215.175.207.239:445 0
*Mar 22 09:31:24.694: %IOSXE-6-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:090 TS:00002348029995181166 %NAT-6-LOG_TRANSLATION: Deleted Translation TCP 192.168.2.64:63006 172.28.127.72:63006 5.59.75.28:445 5.59.75.28:445 0
*Mar 22 09:31:24.700: %IOSXE-6-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:013 TS:00002348030000923941 %NAT-6-LOG_TRANSLATION: Created Translation TCP 192.168.2.251:61836 172.28.127.142:61836 139.17.113.113:445 139.17.113.113:445 0
*Mar 22 09:31:24.700: %IOSXE-6-PLATFORM: F0: cpp_cp: QFP:0.0 Thread:067 TS:00002348030001128521 %NAT-6-LOG_TRANSLATION: Created Translation TCP 192.168.2.80:64566 172.28.127.161:64566 203.123.84.128:445 203.123.84.128:445 0
2 Accepted Solutions
Deepak Kumar
Did you configure " ip nat log translations syslog" command?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
I am happy to know your problem has resolved.
Deepak Kumar
Deepak Kumar,
Deepak Kumar
Deepak Kumar
Deepak Kumar,
Dear Deepak
you right
i checked it and resolve my proble
regards
Deepak Kumar
Deepak Kumar,
thanks alot
