Set Dialer interface to Simultaneously bring up both channels
mks
I was wondering if it is possible to setup a dialer interface (BRI) to always bring up both channels to always allow 128k available instead of using the dialer load-threshold 1 and load-interval 30 commands.
If so could you please give me the commands for this, I would like to be able to run this on 2600 series routers and a 2811 routers.
My thanks in advance for your time and understanding.
Kal
rais.ahmad
How about setting the load threshold, to dial second channel, to 1?
Regards.
m.lammerse
Try:
'ppp multilink links minimum [mandatory]'
To specify the preferred minimum number of links in a Multilink PPP (MLP) bundle, use the ppp multilink links minimum command in interface configuration mode. To reset the default value, use the no form of this command.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/dial_r/dia_n1g.htm#wp1158197
