Set SSH as default for telnet from router
William Childs
I usually initiate a connection from a router to another network device by simply typing the IP address of the destination I want and then press enter. That begins a telnet session.
Router#10.1.1.1       <--------- starts a telnet session, but I want it to use SSH instead
Is there a way to change that default to SSH so that when I just type the IP address it kicks off SSH instead of telnet?
I want it to behave as though I typed:
Router#ssh 10.1.1.1
P.S. Please don't suggest macros or alias soultions as this will not accomplish my goal in a dynamic fashion.
5 Replies 5
cadet alain
line con 0
transport preferred ssh
Alain
This is the output from implementing the preferred/output/input ssh.
CH-3750-core#sh run | b line
line con 0
transport output ssh
line vty 0 4
privilege level 15
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
ntp clock-period 36027693
ntp server 132.163.4.101
ntp server 132.163.4.103
ntp server 24.56.178.140
end
CH-3750-core#10.100.0.125
% Unknown command or computer name, or unable to find computer address
CH-3750-core#ping 10.100.0.125
Sending 5, 100-byte ICMP Echos to 10.100.0.125, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
I also configured the ssh source-interface to be on the same subnet I'm trying to get to. It still works if I use
CH-3750-core#ssh 10.100.0.125
I'm using a 3750x stack of 2 running code c3750e-universalk9-mz.122-55.SE5.bin.
Below is the output to the same router with different syntax to start the ssh session.
Password:
Router#
i've tried it and it didn't work so i made some research and apparently this is not possible. it still uses telnet  not ssh though the word ssh was used. I'll have to dig further to see the use of this keyword then.
Alain
Cadet,
Upon further investigation, I think  it is not possible to change the default behavior. I was reading another forum here and they were discussing something VERY similar to the issue I am asking about, but not quite the same. I believe the reasoning is something like this:
Simply entering the ip address initiates (or attempts to, anyway) a telnet session. Because the transport output ssh command was used you get the results listed above. This means that any time you want to ssh from a cisco router/switch/device you have to use the key word ssh x.x.x.x (with other switches if so desired, like -l for username) and cannot change the way the router interprets simply entering an IP address.
Thanks anyway for your attempt to answer my question.
My understanding is the input command determines what protocols will be allowed in that line. The output command define what protocol you may use to connect to a device going out. so if you do the following:
line vty 0 15
transport input ssh
This device can only be connected to by SSH (on the VTY lines console is a separate line) and will only connect to other devices  via SSH. This however does not change the default action of the router but prevents it from sending out the telnet request.
