Strange problem with Catalyst 4506 and ASA 5545-X
Emrecan Ural
We have a Catalyst 4506 backbone switch with multiple VLANs configured on it. The switch is the default gateway on the network and it does the routing. Default gateway of the backbone switch is a PIX 515E firewall which is connected directly to it. The switch port connected to the PIX firewall is in access mode and it's a member of a VLAN (This VLAN is used for servers in our network).
When we change PIX with ASA 5545-X firewall, all the nodes in the server VLAN stops communicating with each other. When we try to ping a server from another server, first ICMP packet times out but the rest of them travels fine. This behavior can also be observed on the switch such as when we try to ping a server from the switch, the first ICMP packet times out. If we start another ping sequence right after this, every ICMP packet travels fine. But if we wait for approx. 1 minute, the same problem happens again.
We also observe the traffic between the servers, on the ASA monitor, which basically shouldn't be there. For example packets going from server A to server B can be seen on the ASA monitor, but their gateway is the backbone switch.
Any help will be greatly appreciated. You can find the configuration details below. Thanks.
Cisco WS-C4506
interface GigabitEthernet3/16
description Firewall
switchport access vlan 63
switchport mode access
interface Vlan63
ip address X.X.X.X 255.255.255.0
ip route 0.0.0.0 0.0.0.0 X.X.X.Y
Cisco PIX 515E
interface Ethernet1
nameif inside
security-level 100
ip address X.X.X.Y 255.255.255.0
ospf cost 10
Cisco ASA 5545-X
interface GigabitEthernet0/1
nameif inside
security-level 100
tobyarnett
Obvious questions first you didn't lose any routes when you migrated to your asa? All your static statements are in place? Your servers default gateway is the switch not your asa?
Toby
Sent from Cisco Technical Support Android App
-Toby
Please don't forget to rate any helpful post.
_____________________________________
There are no great limits to growth because there are no limits of human intelligence, imagination, and wonder.
- Ronald Reagan
Oh yes, I defined every route that was in PIX to ASA. And the static routes on the backbone switch stayed the same. All of the servers' default gateway is our backbone switch.
The strange thing is that I don't see the traffic between the servers on the PIX monitor. But when I connect ASA, traffic between the servers is visible.
Any suggestions?
jj27
Try this command: sysopt noproxyarp inside
The ASA may be handling ARP requests for all traffic on the servers.
