Set up NAT on cisco 2811
bsciarra1
Good morning, i have a branch router that connects to mpls WAN.  Also has a second interface that is used for dmvpn failover in case WAN goes down.
We want to use this second interface also as the primary internet circuit for the branch.  I changed the default route to the next hop address on the other side of the second interface and expected this to work.
But i was told i need to set up NAT for this to work, and set up an ACL for NAT to use.
Does anyone know how to set up NAT?
Tirumala Earla
I am taking an Example
Your Private IP: 192.168.1.0/24
ISP connected INterface is Serial 0/0
Configuration
R1(config)# access-list 100 remark ---NAT--
R1(config)# access-list 100 permit ip 192.168.1.0 0.0.0.255 any
R1(config)# ip nat inside source list 100 interface serial 0/0 overload
Verification
R1# show ip nat translations
