Setting asymmetrical interface bandwidth on CISCO 2921
Logic2020
I have what I am sure is a simple question, but after reviewing the documentation, I just want to be sure:  I have two internet connections coming into my 2921.  One is a 50/50 symmetrical connection, the other a 100/20.  If I want the router's load balancing logic to work correctly, how do I set the download/upload settings for the second interface correctly.  I have used the 'bandwidth 50000' command for the first interface...would the commend for the second be 'bandwidth 20000 receive 100000'?
Thanks for the help!
6 Replies 6
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Could you further define "If I want the router's load balancing logic to work correctly, . . ."
The reason I ask, what you're looking at is telling the router what expected bandwidths are, which, alone, may not impact actual physical load balancing.  Also, routers can often be configured for egress/outbound physical load balancing, but physical ingress/inbound load balancing can be very difficult to control.  Also, router load balancing is often static, not dynamic.
(Although your question appears simple, the answer often is not.)
Well maybe I'm demonstrating my ignorance :-)  I have both interfaces defined currently.  If I fail one interface (unplug the Ethernet cable to outside), the load fails over to the other connection (tested).  My (perhaps innacurate) understanding was that if I had bother interfaces defined with the same distance parameter, that the router's logic would calculate best path based on load.  If one path is 100/20 and the other 50/50, then it would be throwing outbound traffic to the 100/20 interface when the 50/50 might be the better path.  I looked at this: http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/100658-ios-nat-load-balancing-2isp.html, but I'm not sure I understood it :-(
-Nick
Disclaimer
Posting
Your first reference is static routing load balancing.  Which, I believe, while links are up, would round robin outbound flows.  You second reference is OER, which can dynamically load balance.
Unsure what your follow-up question is.
My desired outcome is:
  • Balance load between two heterogeneous interfaces (100/20 and 50/50) to maximize end user throughput
  • Failover should one of the interfaces become inactive (I've tested that when unplugged the route will adjust...but per the second article, a present but not functional interface may not fail)
What I really want is for the router to be aware of the relative performance of the two pipes and route based on that....available bandwidth would seem just one part of that equation...but once the data has been routed, does it know how the pipe is actually performing?
Disclaimer
Posting
"Normal" routing doesn't react to actual interface load utilization.
OER/PfR can react and actual load utilization.
