setting qos
leungcm
I config the qos as follwing:
we would like
24M for VoIP min
34M for VoIP max
class-map match-any AutoQoS-VoIP-RTP-Trust
match ip dscp ef !Interactive Voice
class-map match-any AutoQoS-VoIP-Control-Trust
match ip dscp cs3 !Telephony Signaling
match ip dscp af31 !voice signaling
policy-map AutoQoS-Policy-Trust
class AutoQoS-VoIP-RTP-Trust
priority percent 70
class AutoQoS-VoIP-Control-Trust
bandwidth percent 5
class class-default
fair-queue
interface Serial1/0
ip address 192.168.2.1 255.255.255.252
auto qos voip trust
dsu bandwidth 44210
service-policy output AutoQoS-Policy-Trust
rate-limit output access-group 130 24000000 10000000 2000 conform-action continue exceed-action drop
access-list 130 permit ip 192.168.30.0.0 0.0.0.255 192.168.101.0 0.0.0.255
anything we need to improve it? thanks
best regards
hoogen_82
Level 4
Level 4
The priority percent is best recommended to be at 33% of the bandwidth available to you.
Also consider this configuration
class-map match-any VOIP
match ip dscp ef
match ip dscp cs3
match ip dscp af31
class-map match-any VOIP_CONTROL
match access-group V_Control
class-map match-any Untrust_VOIP
match access-group Voice_Udp
policy-map QOS
class Untrust_VOIP
priority
set dscp ef
class VOIP_CONTROL
bandwidth
set dscp af31
class VOIP
set dscp default
class class-default
fair-queue
interface fastethernet 0/1
description Output interfaces
service-policy output QOS
ip access-list V-Control
permit tcp any any eq 1720
permit tcp any any range 11000 11999
permit udp any any eq 2427
permit udp any any eq 2428
permit tcp any any range 2000 2002
permit udp any any eq 1719
permit udp any any eq 5060
ip access-list Voice_Udp
permit udp any any range 16384 32768
Hoogen
Do rate if you find this post helpfull :)
another little recommendation: use a policer "always-on" for voip traffic, is the best solution to improuve the QoE (quality of experience) about your voice service. See this example:
policy-map QOS
class VOIP
priority
police
In this case, the policer prevents an oversubscription use of exceeded bandwidth, so in case of congestion your Customer won't experience a worsening of QoS (example: call drop).
Andrea
