Setting up backup 4g LTE and DMVPN
T_tow
I'm trying to set up 4g lte as a back with DMVPN eigrp capability. I'm not sure if my failover is active but my problem right now is my tunnel is up/down.   Thought I'd configured everything right and my cell int is up up but it's not coming up right now on the spoke or the hub.
For next time, please share outputs in text files, it's better when you want to review all posts :-)
On your Hub, is tunnel 5 the Hub tunnel for DMVPN?
Your hub tunnel should looks like:
interface Tunnel1
 ip address x.x.x.x x.x.x.x
 ip nhrp authentication xxxx ==> If you want to have nhrp authentication
 ip nhrp map multicast dynamic
 ip nhrp network-id 1
 ip nhrp redirect
 ip tcp adjust-mss 1360
 tunnel source xxxxxx ==> Source is the interface on which crypto is going to be negotiated. Usually it's your WAN interface
 tunnel mode gre multipoint
 tunnel key xxxx ==> Key for tunnel
 tunnel protection ipsec profile DMVPN-PROFILE1
Then you have your spoke config. Your config looks good, and you also have another way of doing it:
interface Tunnel1
 ip address 10.254.254.30 255.255.255.0
 ip nhrp authentication xxxxxx
 ip nhrp map 10.254.254.1 xx.xx.xx.xx
 ip nhrp map multicast xx.xx.xx.xx
 ip nhrp network-id 11
 ip nhrp nhs 10.254.254.1
 ip nhrp shortcut
 tunnel source xxxxxxxx
 tunnel key xxxxx
Just a question, to be sure we're on the same page. Why would you use tunnel vrf INET-PUBLIC1?
When you setup this and create the same crypto policies on both end, let me know if that come up or not? If not, shut your tunnels, launch debug crypto isakmp and debug crypto ipsec. Put those outpouts from spoke and hub in text files and share them with us.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
11 Replies 11
Francesco Molino
Can you share your config please?
Did you do some debug crypto? If yes can you share them? If not can you run them and share the output?
Francesco
Missed your reply.  Give me one second.
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
! card type command needed for slot/bay 0/1
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization console
aaa authorization exec default group tacacs+ local
aaa session-id common
clock timezone CDT -6 0
clock summer-time CDT recurring
ip vrf INET-PUBLIC1
rd 100:1
no ip domain lookup
ip domain name
ip dhcp excluded-address
ip dhcp pool VOICE
network 10.x.x.x 255.255.255.128
default-router 10.x.x.1
domain-name
option 150 ip 10.x.x.x
subscriber templating
flow record NetFlow-to-Orion
match ipv4 tos
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect interface output
collect counter bytes long
collect counter packets long
flow exporter NewFlow-to-Orion
destination 10.x.x.x
source GigabitEthernet0/0/0
transport udp
flow monitor NetFlow-to-Orion
cache timeout active 60
chat-script script LTE "" "AT!CALL1" TIMEOUT 30 "OK"
voice-card 0/4
no watchdog
license udi pid ISR4451-X/K9 sn FOC214675UN
username admin privilege 15 secret 5 $1$O9k1$ZfXH7/DQAyBRW2yVodQrH1
redundancy
mode none
controller Cellular 0/2/0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
vlan internal allocation policy ascending
track 234 ip sla 1 reachability
crypto keyring DMVPN-KEYRING1 vrf INET-PUBLIC1
pre-shared-key address 0.0.0.0 0.0.0.0 key (#)
crypto isakmp policy 10
encr aes 256
hash sha512
authentication pre-share
group 16
crypto isakmp key 12 address (PUBLIC ADDRESS) no-xauth
crypto isakmp keepalive 30 5
crypto isakmp profile FVRF-ISAKMP-INET-PUBLIC1
match identity address 0.0.0.0 INET-PUBLIC1
crypto ipsec transform-set LAN_VPN esp-aes 256
mode tunnel
no crypto ipsec nat-transparency udp-encapsulation
crypto ipsec profile DMVPN-PROFILE1
set transform-set LENA_LAN_VPN
set isakmp-profile FVRF-ISAKMP-INET-PUBLIC1
crypto map LAN_VPN 10 ipsec-isakmp
! Incomplete
set peer (HUB PUB ADDRESS)
! access-list has not been configured yet
set transform-set LAN_VPN
match address VPN-GRE
interface Loopback0
description GRE LOOPBACK FOR CRYPTO BINDING
ip address 10.X.X.X 255.255.255.255
ip pim sparse-mode
interface Tunnel1
description GRE over VPN to TULSA
bandwidth 2000
ip address 10.X.X.X 255.255.255.252
no ip redirects
ip mtu 1400
ip pim dr-priority 0
ip pim nbma-mode
ip pim sparse-mode
ip nhrp authentication 12345
ip nhrp holdtime 600
ip nhrp nhs (HUB PRIVATE ADDRESS) nbma (HUB PUB ADDRESS)
ip nhrp registration no-unique
ip nhrp shortcut
ip nhrp redirect
if-state nhrp
keepalive 10 3
tunnel source Cellular0/2/0
tunnel key 2
interface GigabitEthernet0/0/0
description LINK TO CORE
no ip address
media-type sfp
negotiation auto
interface GigabitEthernet0/0/0.10
encapsulation dot1Q 10
ip address 10.X.X.X 255.255.255.0
ip helper-address 10.X.X.X
interface GigabitEthernet0/0/0.20
encapsulation dot1Q 20
ip address 10.X.X.X 255.255.255.128
interface GigabitEthernet0/0/1
description LENA WAN UPLINK
no ip address
negotiation auto
interface GigabitEthernet0/0/1.800
description LENA REGIONAL - COX TAG 800
encapsulation dot1Q 800
no cdp enable
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface Cellular0/2/0
description INET4G FAILOVER VPN
bandwidth 2000
ip vrf forwarding INET-PUBLIC1
no ip address
no ip unreachables
ip access-group ACL-INET-PUBLIC-4G in
shutdown
dialer in-band
dialer idle-timeout 30
dialer watch-group 1
pulse-time 1
ip virtual-reassembly
interface Cellular0/2/1
no ip address
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
interface Dialer2
router eigrp 100
network 10.X.X.X 0.0.0.255
network 10.X.X.X 0.0.0.3
redistribute static
ip local policy route-map track-primary-if
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/1 track 234
ip route 0.0.0.0 0.0.0.0 Cellular0/2/0 254
ip route vrf INET-PUBLIC1 0.0.0.0 0.0.0.0 Cellular0/2/0
ip ssh version 2
ip scp server enable
ip access-list extended ACL-INET-PUBLIC-4G
permit udp any any eq non500-isakmp
permit udp any any eq isakmp
permit esp any any
permit udp any any eq bootpc
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any ttl-exceeded
permit icmp any any port-unreachable
permit udp any any gt 1023 ttl eq 1
ip access-list extended VPN-GRE
ip sla 1
icmp-echo 10.X.X.X source-interface GigabitEthernet0/0/1
threshold 1000
timeout 1000
frequency 15
ip sla schedule 1 life forever start-time now
access-list 99 permit 10.X.X.X
access-list 99 deny any log
dialer watch-list 1 ip 127.0.0.255 255.255.255.255
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
snmp-server community LE-Solarwinds RO 99
snmp-server location LaPorte SHELL Data Center
snmp-server contact Tulsa IT x1194
snmp-server host 10.62.80.52 version 2c LE-Solarwinds
tacacs-server host 10.X.X.X
tacacs-server directed-request
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 0 0
transport input all
line vty 5 15
transport input all
event manager applet ACTIVATE-4G
event track 234 state down
action 1 cli command "enable"
action 2 cli command "configure terminal"
action 3 cli command "interface cellular0/2/0"
action 4 cli command "no shutdown"
action 5 cli command "end"
action 99 syslog msg "Primary Link Down - Activating 4G interface"
event manager applet DEACTIVATE-4G
event track 234 state up
action 4 cli command "shutdown"
action 99 syslog msg "Primary Link Restored - Deactivating 4g interface"
end
not really sure how to run the debug crypto?
I see only 1 tunnel with cellular as source interface. You said it was backup cell for dmvpn but don't see any other tunnel.
Bring up the cell interface and run debug crypto isakmp and crypto ipsec.
Share please the config of dmvpn on hub.
Francesco
Sorry about that I meant we have EIGRP over the WAN and that's our primary link.  Wanted to set up 4G as the backup with the DMVPN over 4G.
Configs coming in a sec but with the I put in debug crypto isakmp then went to my cell int. but am I looking for log info??? is that the wrong command?
You need to issue the command term mon when connected through ssh to see debug logs
Francesco
HUB DMVPN
boot-start-marker
boot-end-marker
vrf definition IWAN-TRANSPORT-1
address-family ipv4
exit-address-family
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$..j3$SM3Z6ncA.bBagMB3Jwgcw/
aaa new-model
clock timezone CST -6 0
no ip domain lookup
ip domain name
license udi pid ISR4351/K9 sn FDO20520LDQ
license accept end user agreement
username admin secret 5 $1$EFdT$XYKF.6edGk1iKd5LZNawn0
redundancy
mode none
encr aes 256
hash sha512
group 16
crypto isakmp key 12345 address 96.x.x.x no-xauth
crypto isakmp key 12345 address 50.x.x.x no-xauth
crypto isakmp key 12345 address 173.x.x.x no-xauth
crypto isakmp key 12345 address 64.x.x.x no-xauth
crypto isakmp key 12345 address 164.x.x.x no-xauth
crypto isakmp keepalive 10
crypto ipsec transform-set LENA_LAN_VPN esp-aes 256
mode transport
set peer 50.x.x.x
match address VPN-GRE-BB
crypto map LAN_VPN 20 ipsec-isakmp
set peer 96.x.x.x
match address VPN-GRE-HC
crypto map LAN_VPN 30 ipsec-isakmp
set peer 173.x.x.x
match address VPN-GRE-HOU
crypto map LAN_VPN 40 ipsec-isakmp
set peer 64.x.x.x
match address VPN-GRE-POINTCOMFORT
crypto map LENA_LAN_VPN 50 ipsec-isakmp
set peer 64.x.x.x
match address VPN-GRE-MONACA
crypto map LAN_VPN 60 ipsec-isakmp
! Incomplete
match address VPN-GRE-laporte
interface Loopback1
ip address 10.x.x.x 255.255.255.255
interface Tunnel1
bandwidth 56
ip address 10.x.x.x 255.255.255.252
ip mtu 1460
qos pre-classify
keepalive 10 3
tunnel source Loopback1
tunnel destination 10.x.x.x
tunnel key 2
interface Tunnel2
bandwidth 56
ip mtu 1460
qos pre-classify
keepalive 10 3
tunnel key 2
interface Tunnel3
bandwidth 56
ip mtu 1460
qos pre-classify
keepalive 10 3
tunnel key 2
interface Tunnel4
bandwidth 56
ip mtu 1460
qos pre-classify
keepalive 10 3
tunnel key 2
interface Tunnel5 (SETUP IN QUESTION)
bandwidth 56
ip mtu 1460
qos pre-classify
keepalive 10 3
tunnel key 2
description LENA WAN VPN LAN
ip address 10.x.x.x 255.255.255.0
negotiation auto
description COX INTERNET CRYPTO INT
ip address 64.x.x.x 255.255.255.224
negotiation auto
crypto map LAN_VPN
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
router eigrp 100
network 10.69.x.x 0.0.0.0
network 10.69.x.x 0.0.0.255
network 10.69.x.x 0.0.0.3
network 10.69.x.x 0.0.0.3 (SETUP IN QUESTION)
no ip http server
ip route 0.0.0.0 0.0.0.0 64.x.x name LENA_LAPORTE_VPN_RTR01 (SETUP IN QUESTION)
ip route 4.x.x.x 255.255.255.255 64.X.X.X name EXTERNAL_TEST_HOST
ip route 10.x.x.x 255.255.255.255 64.X.X. name ROUTE_TABLE_INJECTION
ip route 10.x.x.x 255.255.255.255 64.x.x.x name ROUTE_TABLE_INJECTION
ip route 10.69.x.x 255.255.255.255 64.x.x.x name ROUTE_TABLE_INJECTION
ip route 10.x.x.x 255.255.255.255 64.x..xx name ROUTE_TABLE_INJECTION
ip route 10.x.x.x 255.255.255.255 64.x.x.x name ROUTE_TABLE_INJECTION (SETUP IN QUESTION)
ip route 50.x.x.x 255.255.255.255 64.x.x.x name LENA_BB_VPN_RTR01
ip route 64.x.x.x 255.255.255.255 64.x.x.x name LENA_POINTCOMFORT_VPN_RTR01
ip route 96.6x.x.x 255.255.255.255 64.x.x.x name LENA_HC_VPN_RTR01
ip route 164.x.x.x 255.255.255.255 64.x.x.x name LENA_MONACA_VPN_RTR01
ip route 173.x.x.x 255.255.255.255 64.x.x.x name LENA_HOU_VPN_RTR01
ip access-list extended VPN-GRE-BB
permit gre host 10.x.x.x host 10.x.x.x log
ip access-list extended VPN-GRE-HC
permit gre host 10.69.x.x. host 10.69.x.x log
ip access-list extended VPN-GRE-HOU
permit gre host 10.x.x. host 10.69.x.x log
ip access-list extended VPN-GRE-LAPORTE (SETUP IN QUESTION)
ip access-list extended VPN-GRE-MONACA
permit gre host 10.69.x.x. host 10.69.x.x. log
ip access-list extended VPN-GRE-POINTCOMFORT
ip access-list extended VPN-GRE-laporte
access-list 99 permit 10.x.x.x
snmp-server host 10.x.x.x version 2c LE-Solarwinds
tacacs-server host 10.x.x.x
tacacs-server key 7 14240B0601013E393D
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
end
interface Tunnel1
 ip nhrp redirect
interface Tunnel1
 ip nhrp shortcut
 tunnel key xxxxx
Francesco
Hey got it up.  My hub tunnel was missing a few things, nhrp, wrong mtus etc.  With the ios i am running the commands I was trying to add, like enapsulation slip, were  default so that's why they weren't an option.  Guess this cool script I had to automatically engage the 4G when the primary is down won't be needed since the dmvpn tunnel is going over the 4G.
Thanks again
Glad that everything works fine now.
Francesco
