new cisco 887va Router installation
mod0108537733
Dear all
I'll install a cisco 887va-k9 router next week. would you please tell me how to install it to act as  ADSL modem to my LAN  regarding blow informations:
adsl
pppoe
vpi/vci 0/35
username U
password P
kind regards
Mahmoud
18 Replies 18
shanilkumar2003
Dear Mahmoud,
You have to get the PVC, username, password informations from tour ISP, below would be typical configuration for ADSL interface and ethernet interface.
ADSL interface
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
  pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxx
ppp chap password xxxx
ppp pap sent-username xxxx password xxxx
Ethernet Interface
interface GigabitEthernet0/0
no ip address
ip mtu 1492
duplex auto
speed auto
pppoe enable group global
interface Dialer1
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
Thanks *** please rate helpful posts***
Shanil
Thank you Shanil for your replay ,I appreciate that.please tell me what is the difference between these two configurations
I need to connect the RJ11 coming from the wall outlet directly to the router (POTS port), is this connction correct ?
Yes in that case it's Adsl (ATM) interface you have to use the first configuration.
The difference is if you have rj-11 connection from provider you need an Adsl interface on the router. If it's rj-45 wan Ethernet interface is needed in router
Shanil
Thank you Shanil
If I need t connect this 887va router with 1801 cisco router in anther area through site to site vpn
1- I'll use interface ATM0 as source in tunnel ,is that correct?
2- Do I need static public ip in both sites for the vpn ?
3-I saw another configuration for adsl in 887 ,thy use another sub-interface uder interface ATM0 like
#interface  ATM 0.1  point-to-poin
why tis command?
regards
MAhmoud
Dear Mahmoud,
For site to site VPN you have to apply the crypto-map on Dialer interface not on physical interface ATM0
interface Dialer1
crypto map
atleast one side you need static public ip to configure site to site VPN
there is no need for subinterface point-topoint configuration
Shanil
so many thanks to you shanil
I have in site A (Cisco router 1801 which connected to Internet by leased line and LAN is 10.0.0.0/24)
in site B (Cisco router 887va which connected with 4Mbps ADSL connection and LAN is 10.10.10.0/24)
do you provide me with the simplest way to configure  this vpn and prerequisites?
regards;
Mahmoud
Dear Mahmoud,
Hopes both sides you have static ips.
On Cisco 1801
---configure isakmp policy----
crypto isakmp policy 20
encr 3des
hash md5
authentication pre-share
group 2
---configure key ,(x.x.x.x would be public ip address of the other end )
crypto isakmp key 0 xxxxxxxxxxxxxxxx address x.x.x.x no-xauth
---configure ipsec policy -transformset----
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
---configure cryptomap- to tie all the parameters transformset,peer address and acl)
crypto map MY-MAP 5 ipsec-isakmp
set peer x.x.x.x
set transform-set ESP-3DES-SHA
match address MY-ACL
---configure crypto acl-interesting traffic----
ip access-list extended MY-ACL
permit ip 10.0.0.0 0.0.0.255 10.10.10.0 0.0.0.255
---Apply the crypto map on outside interface, if dialer interface apply on dialer interface----
int fa4
ip address y.y.y.y 255.255.255.252
crypto map MY-MAP
The same need to configure the other end 887 router, peer ip and access-list will change as per.
please note that all other parameters used in crypto should be same including the key.
If you have to use internet need to excempt VPN traffic from nating
Hopes this help  ***please rate helpful posts***
Shanil
I have one public ip address ,which interface I can use to configure it whith this public ip?
Hi any wan interafce . The cable has to connect to the wan interface or adsl interface and configure the static public ip.
I tried to configure this real ip under the dialer interface
but it doesnt work
any help please
Hi if its ADSL you have to configure the public static ip on the Dialer only. As below
interface Dialer1
ip address 2.2.2.2 255.255.255.252
encapsulation ppp
dialer pool 1
***Please rate if helps****
interface Dialer1
encapsulation ppp
dialer pool 1
I tried this solution before but doesn't worked
and tried to restart and ip routing again but without success
- I notice i got public ip under dialer interface in 62.x.x.x range by negotiation but ISP assigned 84.x.x.x as static real for me so when i use this static it doesn't work because of  differnt subnets.
I would speak to your ISP to ensure they have actually configured your connection with the static IP address they provided. I have seen it many times where an order form will provide a static IP address but when the connection is configured by the ISP they fail to actually provide this.
thanks I will check it
