Setting up OSPF Neighbours
Stuart D
I'm trying to connect two routers using OSPF, but when issuing a 'sh ip ospf neighbor' the two are not showing as neighbours. Could someone offer some insight as to why this may be?
Here are the configurations for both routers:
R1:
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 198.222.123.18 255.255.255.0
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 198.222.123.0 0.0.0.15 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 Loopback0
R2:
ip address 198.222.123.17 255.255.255.240
clock rate 128000
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
network 10.1.1.0 0.0.0.3 area 0
ip classless
I'm pretty inexperienced with this, so I apologise if it's something super simple.
Thank you in advance
-Stuart
cmarva
Level 4
Level 4
first off, you're using addresses on a different subnet than is defined, and on R1, the mask on s0/0/0 is wrong. What I would suggest is:
R1
ip address 198.222.123.18 255.255.255.240
router ospf 1
network 198.222.123.16 0.0.0.15 area 0
R2
router ospf 1
and see what happens. You can always run a debug right now and see what falls out.
6 Replies 6
Hello
Do you have reach ability between the two rtrs looks?
R1
int Serial0/0/0
ip address 198.222.123.18 255.255.255.0  <---incorrect mask
router ospf 1
no network 198.222.123.0 0.0.0.15 area 0
network 198.222.123.18 0.0.0.0 area 0
R2
int Serial0/0/0
ip address 198.222.123.17 255.255.255.240  <---incorrect mask
router ospf 1
network 198.222.123.17 0.0.0.0 area 0
Kind Regards
Paul
cmarva
Level 4
Level 4
R1
router ospf 1
R2
router ospf 1
remember that when it comes to IGPs, the hellos are sent out on any interface that falls within the defined network range. Since you have it defined as subnet zero, but your interfaces addressed on subnet.16, it won't send out any hellos at all.
Jaderson Pessoa
R2:
clock rate 128000
They dont stay at the same network.
Jaderson Pessoa
*** Rate All Helpful Responses ***
luis_cordova
Hi @Stuart D ,
In R1 correct this:
R1(config)# interface Serial0/0/0
R1(config-if)# no ip add
R1(config-if)# ip address 198.222.123.18 255.255.255.240
Surely it was a typo error when entering the mask in that interface
Stuart D
Thanks everyone for your help! All sorted now, that had me pulling my hair out all afternoon!
