Setting up PPP
Paul Smith
Hi Guys,
I want to set up PPP on my router for testing as a prelude for eventually setting up RADIUS. Most tutorials have the below as their first step;
router# configure terminal
router(config)# interface serial 1/1
router (config-if)# encapsulation ppp
Guess what. My router does not have a serial interface. Why not? Have they been phased out? We are talking about a big 3925E router here. Surely an enterprise router like this is capable of PPP? I cant encapsulate my physical or sub interfaces with PPP either. It is only the subs that accept encapsulation and even then it is only dot1q. Any help/discussion would be appreciated.
Martin Hruby
Hello Paul
There are by default no serial interfaces equipped in the 3925E therefore you cannot run PPP as link-layer protocol. One way to experiment with PPP is to setup PPP over Ethernet, which you can run on normal Ethernet interfaces. For this you need two routers, one to act as a client dialing in, and the other acting as a server authenticating the user. You might also configure RADIUS authentication on the server. For example:
! Router-A (server)
username cisco password 0 cisco123
vpdn enable
bba-group pppoe TEST
  virtual-template 1
ip local pool CLIENTS 192.168.100.100 192.168.100.254
interface FastEthernet 0/0
  pppoe enable group TEST
interface Virtual-Template 1
  ip address 192.168.100.1 255.255.255.0
  ppp authentication chap
  peer default ip address pool CLIENTS
! Router-B (client)
  pppoe-client dial-pool-number 1
interface Dialer 1
  ip address negotiated
  encapsulation ppp
  dialer pool 1
  ppp chap hostname cisco
  ppp chap password cisco123
  ppp ipcp route default
This might be a good start and help you test what you need to.
You can find further information here: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/bbdsl/configuration/12-4t/bba-12-4t-book/bba-ppoe-client.html
Best regards,
Martin
Just to add to your question yes serial interfaces are being phased out of all equipment so you will unlikely see them on any new equipment unless specifically requested , the bandwidth is just not there on a serial interface to be able to support todays general requirements hwics can handle up to 2mb for most wans these days even small remote offices its just not enough and with the push on broadband internet circuits being more commonly available and cheaper they have taken over, even all of our mpls circuits are Ethernet globally now, as Martin has stated above pppoe and pppoa are the more commonly used ppp features these days
Thanks Martin this is helpful. I am guessing that between virtual templates, pppoe enable groups, bba groups and vpdn connections it is possible to accept ppp connections and even possibly use a RADIUS to authenticate. Now I just need to understand how they all tie in together which seems like a mammoth task at the moment. It seems like one can be attached to another which can in turn be attached to another and so on.
Hello Paul
It is indeed possible to use RADIUS to authentication incoming PPP sessions. You may want to play around with your AAA configuration or use something as simple as this:
! Router-A (server)
aaa new-model
aaa authentication ppp PPP-RADIUS group radius
  ppp authentication chap PPP-RADIUS
radius-server host 10.0.0.100 auth-port 1812 acct-port 1813 key cisco777
Where 10.0.0.100 is your RADIUS server.
More information can be found here: http://www.cisco.com/c/en/us/support/docs/security-vpn/terminal-access-controller-access-control-system-tacacs-/10384-security.html
Best regards,
Martin
