port Flapping
jahanzeb.feroze
I have set port channel in my switch Cisco 2960, and i receiving the following error since then,
Error: 40371: 5w2d: %SW_MATM-4-MACFLAP_NOTIF: Host e41f.13fc.7781 in vlan 1 is flapping between port Gi0/17 and port Gi0/15
Please guide me how to fix it, config of my switch is pasted below
Config:
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxxxx
logging count
logging buffered informational
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
username nog1 secret 5 xxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa authentication login console-login local
aaa authentication login vty-login group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
clock timezone pst 5
system mtu routing 1500
ip subnet-zero
no ip source-route
no ip gratuitous-arps
no ip domain-lookup
ip domain-name cdcpak.com
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
 switchport trunk allowed vlan 1
 switchport mode trunk
 speed 1000
interface Port-channel2
 speed 1000
interface GigabitEthernet0/1
 description BA_DMZ (Assigned to Po1 for SMG purpose)
 speed 1000
 channel-group 1 mode active
interface GigabitEthernet0/2
 speed 1000
interface GigabitEthernet0/3
 switchport mode access
 speed 100
 duplex full
interface GigabitEthernet0/4
 speed 1000
interface GigabitEthernet0/5
 speed 100
 duplex full
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
 speed 1000
interface GigabitEthernet0/9
 speed 100
 duplex full
interface GigabitEthernet0/10
interface GigabitEthernet0/11
 speed 100
 duplex full
interface GigabitEthernet0/12
 speed 100
 duplex full
interface GigabitEthernet0/13
 speed 100
 duplex full
interface GigabitEthernet0/14
 description BA_DMZ (Assigned to Po2 for SMG purpose)
 speed 1000
 channel-group 2 mode active
interface GigabitEthernet0/15
 speed 1000
 duplex full
interface GigabitEthernet0/16
 speed 1000
interface GigabitEthernet0/17
 speed 1000
interface GigabitEthernet0/18
 duplex full
interface GigabitEthernet0/19
 duplex full
interface GigabitEthernet0/20
 shutdown
 speed 100
 duplex full
interface GigabitEthernet0/21
 media-type rj45
 speed 100
 duplex full
interface GigabitEthernet0/22
 switchport access vlan 105
 shutdown
 media-type rj45
 speed 100
 duplex full
interface GigabitEthernet0/23
 shutdown
 media-type rj45
 speed 100
 duplex full
interface GigabitEthernet0/24
 switchport trunk allowed vlan 99
interface Vlan1
 no ip address
 no ip route-cache
interface Vlan99
 ip address 10.x.x.x 255.255.255.0
 no ip route-cache
no ip http server
ip tacacs source-interface Vlan99
logging 10.2.41.11
logging 10.1.24.81
logging 10.1.222.35
logging 10.2.8.144
access-list 10 permit 10.1.24.21
access-list 10 permit 10.1.26.27
access-list 10 permit 10.1.26.26
access-list 10 permit 10.25.2.26
access-list 10 permit 10.1.26.31
access-list 10 permit 10.2.41.11
access-list 10 permit 10.1.26.33
access-list 10 permit 10.1.26.32
access-list 10 permit 10.2.41.23
access-list 10 permit 10.2.40.24
access-list 10 permit 10.1.24.81
access-list 10 permit 10.1.222.35
access-list 10 deny   any log
access-list 11 permit 10.2.41.11
access-list 11 permit 10.1.24.81
access-list 11 permit 10.2.8.144
access-list 11 permit 10.1.222.21
access-list 11 permit 10.1.222.20
access-list 11 permit 10.1.222.10
access-list 11 permit 10.1.222.35
access-list 11 deny   any log
no cdp run
snmp-server community t3hz33b RO 11
snmp-server host 10.1.222.35 version 2c t3hz33b
snmp-server host 10.1.24.50 version 2c t3hz33b
snmp-server host 10.1.24.81 version 2c t3hz33b
snmp-server host 10.2.41.11 version 2c t3hz33b
snmp-server host 10.2.8.144 version 2c t3hz33b
tacacs-server host 10.2.8.133 key 7 08154D4205003142425D5C
tacacs-server host 10.1.160.15 key 7 08154D4205003142425D5C
tacacs-server directed-request
radius-server source-ports 1645-1646
control-plane
banner login ^C This network devi^C
line con 0
 exec-timeout 15 0
 logging synchronous
 login authentication console-login
line vty 0 4
 access-class 10 in
 exec-timeout 15 0
 logging synchronous
 login authentication vty-login
line vty 5 15
 access-class 10 in
 exec-timeout 15 0
 logging synchronous
ntp authentication-key 1 md5 0034120D550E1F0721 7
ntp authenticate
ntp trusted-key 1
ntp clock-period 36029386
ntp server 10.1.222.100 key 1 source Vlan99 prefer
end
23 Replies 23
p.imre
There is some misconfiguration regarding the etherchannel:the speed and duplex settings of all member interfaces has to be identical. You should remove duplex full from Gi0/15. You can check the status of the etherchannel with the command show etherchannel summary.
Ok i will try after removing the duplex, and will update incase problem is not solved.
 p.imre is also right, anyway, as long as the ports should have identical configuration that's why I asked you to add duplex full on g0/17 to have them consistent
Also, connected to your IBM? Is that a baremetal server or a Hypervisor deployed?
Make sure you have configured NIC Teaming on your server, you can't  just connect your server to an etherchannel on the switch w/o configuring the peer device e.g., your server
So have you configured NIC Teaming on your server? If not, configure it, make sure to use LACP
What is NIC Teaming? No idea about it.
To put it simply, it's a fancy name for etherchannel on the server side realm
Make sure you configure etherchannel as well on the server
If you can't configure them, remove the port channel configuration. If you dont, you will hvae performance issues not only on your network but also that IBM server of yours
Oh you mean etherchannel should be configure on IBM servers also in order to remove this error, right ?
Else i will remove it from Switch also ?
Yes that's what we are trying to say
Anyway, configuring etherchannel always involves the peer devices being configured
There is no "Automatic" detection/negotiation of the ports.
The server doesn't automatically detect that the switch it's connected to is configured for etherchannel.
Any device whether switch, server, WLCs, routers to name a few always involves configuring BOTH peer devices, always. :D
Ok , thanks a lot, will surely update after performing the suggested steps
Don't forget to rate our suggestions so everyone can see
additionally, this will mark this section answered/closed :D
sure
Problem didnt resolve after removing duplex on gig 0/15
Issue didnt resolve after removing duplex full from gi0/5
Hi Jahanzeb,
"port-channel load-balance src-dst-ip" global command,  should stop the flapping unless the server has not been setup correctly for port channel.
see this link about port channel load balancing
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_53_se/configuration/guide/2960scg/swethchl.html#wp1445110
Before proceeding,
What devices are connected to ports g0/15 and g0/17? Can you verify,
Checking your config:
 speed 1000
 duplex full
and
 speed 1000
 speed 1000
For consistency sake, can you configure the duplex as well on G0/17?
There might be  a problem with the device that it's connected to
g0/15 and g0/17 should be connected to another device in w/c its ports are using LACP as well
If you connected this w/o configuring the peer device, you will have this kind of problem
and this problem is actually quite bad because this can cause a loop in your network e.g., 100% CPU Util on your switches (most likely not only this one)
