Setting up Remote Access IPSEC VPN
hirani89
Here is my config. I am not able to connect to VPN.
Building configuration...
Current configuration : 5979 bytes
! Last configuration change at 08:40:03 UTC Sun Apr 18 2021 by root
version 15.1
hostname RRouter
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
ip dhcp excluded-address 192.168.10.1 192.168.10.50
ip dhcp excluded-address 192.168.20.1 192.168.20.50
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp excluded-address 192.168.10.101 192.168.10.254
ip dhcp excluded-address 192.168.101.1 192.168.101.10
ip dhcp excluded-address 192.168.30.1 192.168.30.50
ip dhcp excluded-address 192.168.40.1 192.168.40.10
ip dhcp pool ONE
 network 192.168.1.0 255.255.255.0
 dns-server 192.168.10.1
 default-router 192.168.1.1
ip dhcp pool TEN
 network 192.168.10.0 255.255.255.0
 dns-server 1.1.1.1 1.0.0.1
 default-router 192.168.10.1
ip dhcp pool TWENTY
 network 192.168.20.0 255.255.255.0
 default-router 192.168.20.1
ip dhcp pool ONEOONE
 network 192.168.101.0 255.255.255.0
 default-router 192.168.101.1
ip dhcp pool THIRTY
 network 192.168.30.0 255.255.255.0
 default-router 192.168.30.1
ip dhcp pool Wifi_Camera
ip dhcp pool fourty
 network 192.168.40.0 255.255.255.0
 default-router 192.168.40.1
ip dhcp pool FIFTY
 network 192.168.50.0 255.255.255.0
 default-router 192.168.50.1
ip dhcp pool WIN1
 host 192.168.10.76 255.255.255.0
 client-identifier 01fc.aa14.28be.c0
ip dhcp pool HA Server
 host 192.168.10.2 255.255.255.0
 client-identifier 01b8.27eb.8ee9.95
ip domain name ssmt.local
ip name-server 1.1.1.1
ip name-server 1.0.0.1
voice-card 0
license udi pid CISCO2921/K9 sn FGL171712X4
hw-module pvdm 0/0
username root privilege 15 password 0 password
username user secret 4 GK32328zogUw41aNsnIiZ9irs2rALsySwMouCKQYxus
redundancy
ip ssh version 2
crypto isakmp policy 100
 encr aes 256
 authentication pre-share
 group 20
 lifetime 3600
crypto isakmp client configuration group GroupVPN
 key groupkey
 pool VPNPool
crypto ipsec transform-set SetVPN esp-aes esp-sha-hmac
crypto dynamic-map DynamicVPN 100
 set transform-set SetVPN
 reverse-route
crypto map StaticMap client authentication list UserVPN
crypto map StaticMap isakmp authorization list GroupVPN
crypto map StaticMap client configuration address respond
crypto map StaticMap 20 ipsec-isakmp dynamic DynamicVPN
interface Loopback100
 description hairpin
 ip address 169.254.255.254 255.255.255.255
 ip nat inside
 ip virtual-reassembly in
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.100
 description -Internet-
 encapsulation dot1Q 100
 ip address 123.123.123.123 255.255.255.252
 no ip redirects
 ip nat outside
 ip nat enable
interface GigabitEthernet0/1
 no ip address
 ip pim dense-mode
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1.1
 encapsulation dot1Q 1 native
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.10
 ip address 192.168.10.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.30
 encapsulation dot1Q 30
 ip address 192.168.30.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.40
 encapsulation dot1Q 40
 ip address 192.168.40.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.50
 encapsulation dot1Q 50
 ip address 192.168.50.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.101
 encapsulation dot1Q 101
 ip address 192.168.101.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 no ip address
 shutdown
 negotiation auto
ip local pool VPNPool 192.168.10.20 192.168.10.50
ip default-gateway 123.123.123.122
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat source static tcp 192.168.10.1 22 interface GigabitEthernet0/0.100 10122
ip nat inside source list NAT interface GigabitEthernet0/0.100 overload
ip nat inside source static tcp 192.168.30.3 8000 interface GigabitEthernet0/0.100 18000
ip nat inside source static udp 192.168.30.3 8000 interface GigabitEthernet0/0.100 18000
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0.100 27.32.231.217
ip access-list standard NAT
 permit 192.168.0.0 0.0.255.255
ip access-list extended NatPin
 permit ip 192.168.0.0 0.0.255.255 any
 permit ip 192.168.30.0 0.0.0.255 any
route-map NAT_PBR permit 10
 set interface Loopback100
control-plane
mgcp profile default
gatekeeper
 shutdown
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 privilege level 15
 login local
 transport input ssh
line vty 5 15
 login local
 transport input all
scheduler allocate 20000 1000
end
try and add the lines marked in bold:
--> match address 101
reverse-route
--> crypto map StaticMap local-address Loopback100
--> access-list 101 permit ip 192.168.10.0 0.0.0.255 any
Hi Georg,
Sorry that didn't work.
