ibgp
milo34
Hello everyone,
How do i overcome the ibgp rule not to advertise a BGP advertisement learnt from one iBGP neighbor to another iBGP neighbor?
as in my topology i need router loopbacks advertised via ibgp.
all routers have ospf enabled and conectivity
all routers have ibgp peering
r2 and r3 cant see each other loopbacks
for every router config is as follow
r1:
neigh 10.1.12.2 remote-as 65000
neigh 10.1.14.4 remote-as 65000
neigh 10.1.13.3 remote-as 65000
network 1.1.1.1 mask 255.255.255.255
etc...
all the config is correct but i need to evercome the advertisment rule.
Thank you
Giuseppe Larosa
Hello ,
you can use Route Reflector Servers or confederation AS with mini AS.
The first method is easier to implement.
On a selected router that should act as a BGP reflector  server for  some other iBGP peers you just need to add for each "client" peer the line
neighbor   x.x.x.x    route-reflector-client
This eliminates the need for a full mesh of iBGP sessions between clients of the RRS.
The RRS will propagate a client's prefix to all of its clients and ot all non clients iBGP peers.
The RRS will propagate to all clients a route learned from a non client iBGP peer.
The RRS devices need a full mesh of standard iBGP sessions between them.
For redundancy purposes each set of clients can be served by two RRS that can configure the same cluster-id  or a different one .
RRS adds two BGP attributes that allow fo safe reflection:
Originator -ID : BGP RID of the client that injected the prefix in the iBGP domain
Cluster list: it is a list of all the BGP RRS that the route has been propagated through when not set with cluster-id command the cluster-id = BGP RID of RRS.
in MP BGP implementations the neighbor ..... route-reflector-client command can be given in a specific address family and this can lead to RRS specialization in MPLS SP networks ( some RRS are used for global routing table others for VPNv4 services )
Edit:
advertising the local loopback in iBGP is not needed and not recommended advertise it in the underlying IGP OSPF
Hope to help
Giuseppe
Giuseppe Larosa
Hello ,
Edit:
Hope to help
Giuseppe
milo34
thank you Giuseppe. just sorted with RR.
