Setting up SFTP (NAT/ACL)
damianmoran
Can't seem to get this to work, need remote connections on port 22 (800 series).
aghaznavi
Level 5
Level 5
You cannot edit the values that pertain to Video Portal Metadata files. To specify the deployment locations ? which can differ for the different supported filetypes ? select Setup > Deployment Locations, then enter all of the following values for every supported filetype that you selected in Task 17. Any invalid entries will cause deployments to fail:
Connection type ? The protocol or method for file transfer (the options are FTP, SFTP, and SCP
