Setting up site to site IPSec VPN
angristan
Hello everyone!
I need help to set up my IPSec VPN.
Here is my topology in GNS3:
I'm trying to setup a VPN between ffw.par.rt01 and each of the other router (mar,lim,nan). Meaning every VPCS can access the ffw.par.* VPCS via the VPN, and the ffw.par.* VPCS can access the other VPCS via the VPN.
First, I'm trying to set up the VPN between ffw.par.rt01 and ffw.mar.rt01.
Config on the routers before setting up the VPN:
ffw.par.rt01#sh running-config
Building configuration...
Current configuration : 4075 bytes
version 15.6
hostname ffw.par.rt01
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
no process cpu autoprofile hog
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no cdp log mismatch duplex
no cdp run
ip tcp synwait-time 5
interface GigabitEthernet0/0
 ip address 72.145.30.10 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 10.0.2.1 255.255.255.240
 ip access-group 110 in
 ip nat inside
 no cdp enable
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 10.0.2.17 255.255.255.248
 ip access-group 120 in
 ip nat inside
 no cdp enable
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
interface GigabitEthernet0/3
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 72.145.30.0 255.255.255.252 72.145.30.9
ip route 72.145.30.4 255.255.255.252 72.145.30.9
ip route 72.145.30.12 255.255.255.252 72.145.30.9
access-list 1 permit 10.0.2.0 0.0.0.15
access-list 1 permit 10.0.2.16 0.0.0.7
access-list 110 deny   ip 10.0.2.0 0.0.0.15 10.0.2.16 0.0.0.7
access-list 110 permit ip any any
access-list 120 deny   ip 10.0.2.16 0.0.0.7 10.0.2.0 0.0.0.15
access-list 120 permit ip any any
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS  *
* education. IOSv is provided as-is and is not supported by Cisco's      *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any       *
* purposes is expressly prohibited except as otherwise authorized by     *
* Cisco in writing.                                                      *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
 transport input none
no scheduler allocate
end
ffw.mar.rt01#sh run
Current configuration : 4077 bytes
version 15.6
hostname ffw.mar.rt01
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no cdp run
 ip address 72.145.30.14 255.255.255.252
 ip nat outside
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 no ip address
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 ip address 10.0.0.1 255.255.255.240
 ip nat inside
 no cdp enable
 ip address 10.0.0.17 255.255.255.248
 ip nat inside
 no cdp enable
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
no ip http server
ip route 72.145.30.0 255.255.255.252 72.145.30.13
ip route 72.145.30.4 255.255.255.252 72.145.30.13
ip route 72.145.30.8 255.255.255.252 72.145.30.13
access-list 1 permit 10.0.0.0 0.0.0.15
access-list 1 permit 10.0.0.16 0.0.0.7
access-list 110 deny   ip 10.0.0.0 0.0.0.15 10.0.0.16 0.0.0.7
access-list 120 deny   ip 10.0.0.16 0.0.0.7 10.0.0.0 0.0.0.15
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
Now, the VPN configuration. Below I have listed the steps I used on each router:
ffw.par.rt01(config)#crypto isakmp policy 5
ffw.par.rt01(config-isakmp)#hash sha
ffw.par.rt01(config-isakmp)#authentication pre-share
ffw.par.rt01(config-isakmp)#group 2
ffw.par.rt01(config-isakmp)#lifetime 86400
ffw.par.rt01(config-isakmp)#encryption 3des
ffw.par.rt01(config-isakmp)#exit
ffw.par.rt01(config)#crypto isakmp key cisco@123 address 72.145.30.14
ffw.par.rt01(config)#crypto ipsec transform-set MY-SET esp-aes 128 esp-md5-hmac
ffw.par.rt01(cfg-crypto-trans)#crypto ipsec security-association lifetime seconds 3600
ffw.par.rt01(config)#ip access-list extended VPN-TRAFFIC
ffw.par.rt01(config-ext-nacl)#permit ip 10.0.2.0 0.0.0.255 10.0.0.0 0.0.0.255
ffw.par.rt01(config-ext-nacl)#permit ip 10.0.2.0 0.0.0.255 10.0.1.0 0.0.0.255
ffw.par.rt01(config-ext-nacl)#permit ip 10.0.2.0 0.0.0.255 10.0.3.0 0.0.0.255
ffw.par.rt01(config)#crypto map IPSEC-SITE-TO-SITE-VPN 10 ipsec-isakmp
ffw.par.rt01(config-crypto-map)#match address VPN-TRAFFIC
ffw.par.rt01(config-crypto-map)#set peer 72.145.30.14
ffw.par.rt01(config-crypto-map)#set transform-set MY-SET
ffw.par.rt01(config)#int g0/0
ffw.par.rt01(config-if)#crypto map IPSEC-SITE-TO-SITE-VPN
# Exclude VPN traffic from NAT Overload
ffw.par.rt01(config)#ip access-list extended 1
ffw.par.rt01(config-ext-nacl)#deny ip 10.0.2.0 0.0.0.255 10.0.0.0 0.0.0.255
ffw.par.rt01(config-ext-nacl)#deny ip 10.0.2.0 0.0.0.255 10.0.1.0 0.0.0.255
ffw.par.rt01(config-ext-nacl)#deny ip 10.0.2.0 0.0.0.255 10.0.3.0 0.0.0.255
ffw.par.rt01(config-ext-nacl)#permit ip 10.0.2.0 0.0.0.255 any
ffw.par.rt01(config-ext-nacl)#exit
ffw.par.rt01(config)#ip nat inside source list 101 interface gigabitEthernet 0/0 overload
ffw.mar.rt01(config)#crypto isakmp policy 5
ffw.mar.rt01(config-isakmp)#hash sha
ffw.mar.rt01(config-isakmp)#authentication pre-share
ffw.mar.rt01(config-isakmp)#group 2
ffw.mar.rt01(config-isakmp)#lifetime 86400
ffw.mar.rt01(config-isakmp)#encryption 3des
ffw.mar.rt01(config-isakmp)#exit
ffw.mar.rt01(config)#crypto isakmp key cisco@123 address 72.145.30.10
ffw.mar.rt01(config)#crypto ipsec transform-set MY-SET esp-aes 128 esp-md5-hmac
ffw.mar.rt01(cfg-crypto-trans)#crypto ipsec security-association lifetime seconds 3600
ffw.mar.rt01(config)#ip access-list extended VPN-TRAFFIC
ffw.par.rt01(config-ext-nacl)#permit ip 10.0.0.0 0.0.0.255 10.0.1.0 0.0.0.255
ffw.par.rt01(config-ext-nacl)#permit ip 10.0.0.0 0.0.0.255 10.0.2.0 0.0.0.255
ffw.par.rt01(config-ext-nacl)#permit ip 10.0.0.0 0.0.0.255 10.0.3.0 0.0.0.255
ffw.mar.rt01(config)#crypto map IPSEC-SITE-TO-SITE-VPN 10 ipsec-isakmp
ffw.mar.rt01(config-crypto-map)#match address VPN-TRAFFIC
ffw.mar.rt01(config-crypto-map)#set peer 72.145.30.10
ffw.mar.rt01(config-crypto-map)#set transform-set MY-SET
ffw.mar.rt01(config)#int g0/1
ffw.mar.rt01(config-if)#crypto map IPSEC-SITE-TO-SITE-VPN
ffw.mar.rt01(config)#ip access-list extended 101
ffw.par.rt01(config-ext-nacl)#deny ip 10.0.0.0 0.0.0.255 10.0.1.0 0.0.0.255
ffw.par.rt01(config-ext-nacl)#deny ip 10.0.0.0 0.0.0.255 10.0.2.0 0.0.0.255
ffw.par.rt01(config-ext-nacl)#deny ip 10.0.0.0 0.0.0.255 10.0.3.0 0.0.0.255
ffw.par.rt01(config-ext-nacl)#permit ip 10.0.0.0 0.0.0.255 any
ffw.mar.rt01(config-ext-nacl)#exit
OK. So far no error.
Now let's try pinging par from mar:
VPCS> ping 72.145.30.10
84 bytes from 72.145.30.10 icmp_seq=1 ttl=253 time=50.915 ms
84 bytes from 72.145.30.10 icmp_seq=2 ttl=253 time=24.942 ms
84 bytes from 72.145.30.10 icmp_seq=3 ttl=253 time=27.652 ms
84 bytes from 72.145.30.10 icmp_seq=4 ttl=253 time=46.881 ms
^C
VPCS> ping 10.0.2.1
*10.0.0.1 icmp_seq=1 ttl=255 time=24.070 ms (ICMP type:3, code:1, Destination host unreachable)
*10.0.0.1 icmp_seq=2 ttl=255 time=18.625 ms (ICMP type:3, code:1, Destination host unreachable)
*10.0.0.1 icmp_seq=3 ttl=255 time=45.900 ms (ICMP type:3, code:1, Destination host unreachable)
^C
VPCS> ping 10.0.2.2
*10.0.0.1 icmp_seq=1 ttl=255 time=71.359 ms (ICMP type:3, code:1, Destination host unreachable)
*10.0.0.1 icmp_seq=2 ttl=255 time=24.515 ms (ICMP type:3, code:1, Destination host unreachable)
*10.0.0.1 icmp_seq=3 ttl=255 time=18.195 ms (ICMP type:3, code:1, Destination host unreachable)
*10.0.0.1 icmp_seq=4 ttl=255 time=48.356 ms (ICMP type:3, code:1, Destination host unreachable)
*10.0.0.1 icmp_seq=5 ttl=255 time=25.838 ms (ICMP type:3, code:1, Destination host unreachable)
As you can see I can't access the VPCS.
What did I miss? Is it about the access-lists? I tried to be careful about NAT but it's easy to mess up...
Thanks for your help.
7 Replies 7
remove the access lists on your subinterfaces (no access-group 110/120), and use the VPN and NAT access lists below:
ffw.par.rt01
ffw.mar.rt01
EDIT: it would be easier to troubleshoot your configs if you would post the full running configs including all the VPN stuff...a consolidated config so to speak.
First of all, thank you for your answer.
Here is my config after setting up the VPN + applying your suggested changes (which apparently did not help):
Current configuration : 4795 bytes
! Last configuration change at 22:06:55 UTC Sun Jun 2 2019
version 15.6
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no cdp run
 encr 3des
 group 2
crypto ipsec transform-set MY-SET esp-aes esp-md5-hmac
 mode tunnel
 ip nat outside
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 no ip address
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 ip nat inside
 no cdp enable
 ip nat inside
 no cdp enable
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
no ip http server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
access-list 101 deny   ip 10.0.2.0 0.0.0.255 10.0.0.0 0.0.0.255
access-list 101 deny   ip 10.0.2.0 0.0.0.255 10.0.1.0 0.0.0.255
access-list 101 deny   ip 10.0.2.0 0.0.0.255 10.0.3.0 0.0.0.255
access-list 101 permit ip 10.0.2.0 0.0.0.255 any
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
ffw.mar.rt01#sh running-config
*Jun  2 22:10:08.517: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 4797 bytes
! Last configuration change at 22:10:08 UTC Sun Jun 2 2019
version 15.6
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no cdp run
 encr 3des
 group 2
 mode tunnel
 ip nat outside
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 no ip address
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 ip nat inside
 no cdp enable
 ip nat inside
 no cdp enable
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
no ip http server
access-list 101 deny   ip 10.0.0.0 0.0.0.255 10.0.1.0 0.0.0.255
access-list 101 deny   ip 10.0.0.0 0.0.0.255 10.0.2.0 0.0.0.255
access-list 101 deny   ip 10.0.0.0 0.0.0.255 10.0.3.0 0.0.0.255
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
there are still numerous misconfigurations which cause the VPN to malfunction. Make sure that the access lists, NAT and route statements, and the interface configurations look exactly like the below:
ffw.par.rt01
encr 3des
group 2
mode tunnel
ip nat outside
duplex auto
speed auto
media-type rj45
no cdp enable
ip nat inside
no cdp enable
ip nat inside
no cdp enable
ip route 0.0.0.0 0.0.0.0 72.145.30.9
ffw.mar.rt01#
encr 3des
group 2
mode tunnel
ip nat outside
duplex auto
speed auto
media-type rj45
no cdp enable
ip nat inside
no cdp enable
ip nat inside
no cdp enable
ip route 0.0.0.0 0.0.0.0 72.145.30.14
Here is my current config:
ffw.par.rt01
 encr 3des
 group 2
 mode tunnel
 ip nat outside
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 no ip address
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 ip nat inside
 no cdp enable
 ip nat inside
 no cdp enable
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
no ip http server
ffw.mar.rt01
 encr 3des
 group 2
 mode tunnel
 ip nat outside
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 no ip address
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 ip nat inside
 no cdp enable
 ip nat inside
 no cdp enable
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
no ip http server
ip route 0.0.0.0 0.0.0.0 72.145.30.13
My ACLs were quite a mess, and this configuration makes sense. But now my VPCS test timeouts:
ffw.mar.pc-res01
84 bytes from 72.145.30.10 icmp_seq=1 ttl=253 time=33.305 ms
84 bytes from 72.145.30.10 icmp_seq=2 ttl=253 time=17.636 ms
84 bytes from 72.145.30.10 icmp_seq=3 ttl=253 time=13.641 ms
84 bytes from 72.145.30.10 icmp_seq=4 ttl=253 time=35.256 ms
84 bytes from 72.145.30.10 icmp_seq=5 ttl=253 time=15.862 ms
VPCS> ping 10.0.2.1
10.0.2.1 icmp_seq=1 timeout
10.0.2.1 icmp_seq=2 timeout
10.0.2.1 icmp_seq=3 timeout
10.0.2.1 icmp_seq=4 timeout
10.0.2.1 icmp_seq=5 timeout
VPCS> ping 10.0.2.2
10.0.2.2 icmp_seq=1 timeout
10.0.2.2 icmp_seq=2 timeout
10.0.2.2 icmp_seq=3 timeout
10.0.2.2 icmp_seq=4 timeout
10.0.2.2 icmp_seq=5 timeout
On the router:
ffw.mar.rt01#ping 10.0.2.2
Sending 5, 100-byte ICMP Echos to 10.0.2.2, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
ffw.mar.rt01#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 72.145.30.13 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 72.145.30.13
      10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
C        10.0.0.0/28 is directly connected, GigabitEthernet0/1.10
L        10.0.0.1/32 is directly connected, GigabitEthernet0/1.10
C        10.0.0.16/29 is directly connected, GigabitEthernet0/1.20
L        10.0.0.17/32 is directly connected, GigabitEthernet0/1.20
      72.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        72.145.30.12/30 is directly connected, GigabitEthernet0/0
L        72.145.30.14/32 is directly connected, GigabitEthernet0/0
The routes seem correct, so I assume this is an issue with the VPN?
Hello!
Does anyone have an idea?
The VPN seems down:
ffw.par.rt01#show crypto session
Crypto session current status
Interface: GigabitEthernet0/0
Session status: DOWN
Peer: 72.145.30.14 port 500
IPSEC FLOW: permit ip 10.0.2.0/255.255.255.0 10.0.0.0/255.255.255.0
Active SAs: 0, origin: crypto map
OK, I figured it out:
I applied the crypto map on g0/1 on ffw.mar.rt01 instead of g0/0.
It's working now!
