SFP-10G-SR shutting down port 0/0/3 automatically on ASR-920-4SZ
kdsingh007
I have inserted
SFP-10G-SR to  port te0/0/3  on ASR-920-4SZ
and found that it shuts down the port automatically. This
ASR 920
has 1 gig license. does it mean that this
sfp
is not compatible?
IDPROM for transceiver TenGigabitEthernet0/0/3:
Description = SFP or SFP+ optics (type 3)
Transceiver Type: = SFP+ 10GBASE-SR (273)
Product Identifier (PID) = SFP-10G-SR
Vendor Revision = 1.0
Serial Number (SN) = xxxxxxxxx
Vendor Name = xxxxx
Vendor OUI (IEEE company ID) = xxxxx
CLEI code = xxxxxxx
Cisco part number = xxxxxx
Device State = Enabled.
Date code (yy/mm/dd) = 22/08/11
Connector type = LC.
Encoding = 64B/66B (6)
Nominal bitrate = (10300 Mbits/s)
Minimum bit rate as % of nominal bit rate = not specified
Maximum bit rate as % of nominal bit rate = not specified
R2#sh facility-alarm status
System Totals Critical: 1 Major: 0 Minor: 0
Source Time Severity Syslog String Description [Index]
GigabitEthernet0 Sep 14 2023 02:21:51 CRITICAL ETHERNET_PORT_LINK_DOWN Physical Port Link Down [1]
GigabitEthernet0/0/0 Sep 14 2023 14:58:53 INFO ETHERNET_PORT_ADMIN_DOWN Physical Port Administrative State Down [2]
GigabitEthernet0/0/1 Sep 14 2023 14:58:53 INFO ETHERNET_PORT_ADMIN_DOWN Physical Port Administrative State Down [2]
TenGigabitEthernet0/0/3 Sep 14 2023 14:58:53 INFO ETHERNET_PORT_ADMIN_DOWN Physical Port Administrative State Down [2]
OR# sh license
Index 1 Feature: advancedmetroipaccess
Period left: Not Activated
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
Index 2 Feature: metroipaccess
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Index 3 Feature: metroaccess
Index 4 Feature: 1588
Index 5 Feature: 10GEupgradelicense
Index 6 Feature: 2portGE-4ports10GE
M02@rt37
Hello @kdsingh007,
SFP+ 10G SR
is compatible with your Router. You need 10G license.
--see Table 1:
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/routers/asr920/configuration/guide/csa/csa-xe-3-13s-asr-920-book/csa-xe-3-13s-asr-920-book1G-10G-ports.html.xml
There are 4*10G ports that operate in 1G mode by default. To operate in 10G mode, you have to activate
10 GigabitEthernet Upgrade license
with single bundle or two bundles.
Best regards
The 10G license is needed to support a
10G SFP+ like the SFP-10G-SR
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
M02@rt37
Hello @kdsingh007,
SFP+ 10G SR
--see Table 1:
Best regards
