SFP Module (urgent)
Mohamed Sobair
Level 7
Level 7
Hi All,
I have a cisco Switch (3560 G), its connected to other device through the SFP port. Now , we are occasionally facing a link failure on the port, we noticed the fiber connector on the other device is asingle mode, while we are using a tranceiver to convert the fiber to Multimode.
My question is:
why is this happening?
Does the SFP support single mode fiber?
Is there any tips of connecting the tranceiver to the SFP port for convertion?
Appreciate any help,
ahmednaas
Level 4
Level 4
You get different types of SFP's: SM, MM, Copper.
Wouldn't it be beter if you had the same type of SFP as your other device? (I am assuming it has a fixed connector).
