SFP not working with LES Circuit Transceiver, GBIC does?
scott-goodwin
Hi Guys,
Was wondering if any of you had come across a similar (in-compatability) issue.
This weekend we were sheduled to upgrade our core from sup2 to 720's.
However when we change the WAN link (les circuit) to the new core the fibre doesn't come up but the transciever sees the link as connected.
The main physical difference is that instead of using a 16 port gbic blade we are now using using the new SFP style connections.
They are like for like, in that the old connection was from the LES Transciever to a LH/LX GBIC. The fibre is MM across the main fibre run then a conditioning patch is used into the LX GBIC.
However when we do Exactly the same with SFP's i.e LH-MM SFP instead of GBIC the link just doesn't come up.
Everything works fine Cisco to cisco, the new SFP's seem to have an issue with the LES transciever.
I have tried numerous fibre and SFP combinations but can't get the link to come up.
Has anyone had a similar issue?
Thanks Scott
paolo bevilacqua
Excuse if it is an obvious question.
Are you using origina Cisco SFPs ?
What the show port says ?
Yes original Cisco Kit.
And port just shows as noconnect??
Above should read LH-SM byt the way ;)
