SFP Unsupported mode in Cisco Catalyst 3750-X?
buu
I am looking to uplink an HP Blade Chassis to a Cisco 3750-X with SFP+ for 10Gig on each end.
I would like to use Direct Attached SFP+ cables if possible.
I already know that the HP Virtual Connect module will not accept a Cisco Direct Attached cable at the current firmware.
Cisco Nexus 5000 has a feature allowing connectivity with the HP Direct Attached cable using "unsupported" mode.
Does anyone know if the 3750-X has this feature as well?
Thanks in advance.
9 Replies 9
John Blakley
My 3750 doesn't support unsupported modules. It could be the IOS version that I have. If yours DOES support it, you'd have:
service unsupported-transceiver
You can also put:
no errdisable detect cause gbic-invalid
If it works, Cisco won't support it (obviously).
HTH,
John
HTH, John *** Please rate all useful posts ***
I would also like to mention that on the 3750x (and probably any that support this) that you need to either re-insert the modules or reload the switch for them to appear useable.
I know that not all transceivers will be supported with this, but anyone know if this should work with Finisar FCLF-8521-3 Active Copper SFP (Gigabit Ethernet) modules?   Most every other brand of switches supports these.
brijesh.saini05
I have the same issue, as due to budget issue we bought non cisco SFP modules ( GLC-EX-SMD) and GLC-FE-100LX-RGD) for our switces 2520CGS-116-8PC. Now even after running service unsupported-transceiver and errdisable detect cause gbic-invalid. I am getting still same issue
%PHY-4-SFP_NOT_SUPPORTED: The SFP in Fa0/2 is not supported.
Please help
GLC-EX-SMD is not supported with 2520CGS-116-8PC.
For GLC-FE-100LX-RGD, what IOS is your CGS running?  It should be at least 12.2(53)EX (and later).
Hi Leo,
Please note model Cisco 2520-116-8PC is typo mistake plese read it Cisco 2520-16-8PC.
My IOS version is 12.2(58)EY2.
Thanks & Regards
Brijesh Saini
And you are getting error messages, about "SFP_NOT_SUPPORTED", when you use GLC-FE-100LX-RGD?
Yes, i am getting this issue, even after using the given commands.
Contact Cisco TAC.
I'm out of ideas.
