Cisco 1130ag Access Point Image Upgrade
humair.amil
Hi all,
I was just trying to upgrade my first cisco access point at home. I am a bit lost...
a) I can't run "conf t" command.
b) It seems to have ver 3 or ver 4 lwapp image running on it.
c) keeps rebooting itself when it starts up and says "certificate is invalid"
I am attaching some screenshots, if you could have a look when you have a minute and guide me in the right direction then I will be highly grateful to you.
Thanks.
27 Replies 27
Leo Laohoo
What are you trying to do?
Your AP is running controller-based IOS (RCV) and the only way for you to upgrade this firmware is when you upgrade the firmware of the controller.
When you upgrade the firmware of the controller, the controller will determine if the APs attached to the controller should synchronize their firmware with the controller or not.  If they do, the controller will push the correct firmware to the APs.
I am trying to upgrade the AP so that it uses 7.3 LWAPP image version. I need to run that so that it could connect to the Cisco Virtual Wireless LAN Controller.
My Cisco vWLC is already on the 7.4 version but the Access Points still fails to connect to it or download image from it.
No you don't.
Let the AP join the WLC and the WLC will take care of the firmware of the AP.
Leo,
The AP keeps rebooting itself. The WLC picks it up for a second but looses it again. On the AP console I can see errorr messages "Certificate is not valid" etc.
I will try and post the screen shot of error message that it is giving me.
So this is the error that I get. The AP reboots everytime after displaying that error message.
"No more AP Manager IP Addresses remaining" is the vital error message.
How many APs can your WLC support and how many are currently registered?
Post the following command outputs:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version; and
4.  AP:  sh inventory
PS:  Don't post screenshots.  Copy-and-paste the result here or in a notepad.
Show Sysinfo on WLC
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.100.60
RTOS Version..................................... 7.4.100.60
Bootloader Version............................... 7.4.100.60
Emergency Image Version.......................... 7.4.100.60
Build Type....................................... DATA + WPS
System Name...................................... Cisco_b9:b6:23
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 192.168.1.240
System Up Time................................... 4 days 1 hrs 5 mins 52 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 00:0C:29:B9:B6:23
Maximum number of APs supported.................. 200
Show Time on WLC
Time............................................. Tue Jun 18 00:03:26 2013
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
    NTP Polling Interval.........................     3600
     Index     NTP Key Index     NTP Server      NTP Msg Auth Status
       1              0       81.168.77.149       AUTH DISABLED
Show ver on AP
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.3(11)JX1, RELEA        SE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:38 by alnguyen
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (        fc2)
144AP1 uptime is 7 minutes
System returned to ROM by reload
System image file is "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx"
cisco AIR-LAP1131AG-E-K9   (PowerPCElvis) processor (revision A0) with 24566K/81        92K bytes of memory.
Processor board ID FCZ1225Q1JN
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from reload
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1E:F7:EE:58:76
Part Number                          : 73-8962-12
PCA Assembly Number                  : 800-24818-11
PCA Revision Number                  : B0
PCB Serial Number                    : FOC12230B10
Top Assembly Part Number             : 800-29144-02
Top Assembly Serial Number           : FCZ1225Q1JN
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131AG-E-K9
Show Inventory on AP
does not produce any results.
Your WLC is configured for the US, regulatory domain of "-A".
Your AP has a regulatory domain of Europ, "-E".
These are the main reasons why your AP won't join the WLC.
Exactly WHERE are you planning to install the AP?  What country?
I am going to deploy it in the UK. Just trying to build a home lab to practice before taking the CCNA Wireless exam.
How would I change this on the Controller to match the AP settings?
Thank you for your help.
Wireless > Country
Leo,
Sorry for the late reply. I have made changes as advised by yourself but I am still getting the same error message. Could you please help?
Humair
Console into the AP and reboot the AP.
Post the entire bootup process.
144AP1#reload
%Reload in progress
144AP1#Xmodem file system is available.
flashfs[0]: 8 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 5496832
flashfs[0]: Bytes available: 10502144
flashfs[0]: flashfs fsck took 27 seconds.
Base ethernet MAC Address: 00:1e:f7:ee:58:76
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx"...#########################################################################################################################################################################
File "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Image text-base: 0x00003000, data-base: 0x0035E440
Initializing flashfs...
flashfs[1]: 8 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 5496832
flashfs[1]: Bytes available: 10502144
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
cisco AIR-LAP1131AG-E-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Press RETURN to get started!
*Mar  1 00:00:06.072: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 00:00:06.078: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:07.034: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:08.034: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar  1 00:00:16.033: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:25.097: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:00:36.499: LWAPP_CLIENT_ERROR_DEBUG: spamHandleDiscoveryTimer : Found the discovery response from MASTER Mwar
*Mar  1 00:00:36.508: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Jun 21 22:43:12.002: LWAPP_CLIENT_ERROR_DEBUG:
*Jun 21 22:43:12.002: peer certificate verification failed
*Jun 21 22:43:12.002: LWAPP_CLIENT_ERROR_DEBUG: spamDecodeJoinReply : Certificate is not valid
*Jun 21 22:43:12.002: LWAPP_CLIENT_ERROR_DEBUG: Unable to decode join reply
*Jun 21 22:43:16.980: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not recieve the Join response
*Jun 21 22:43:16.980: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses remain.
*Jun 21 22:43:17.017: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET JOIN RESPONSE.
*Jun 21 22:43:17.017: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
Can you post the output to the WLC command: sh sysinfo
Sent from Cisco Technical Support Nintendo App
