SG350x to ASR for Internet
pgreen
I have a SG350x-48P that I have turned L3 on.  I have 4 VLANS that all have 172.16.15.0/26 and DHCP Pools for each.  They all hand out IP addresses on their respective interface that have the vlan membership.  I have one connection to and ASR1001 and a. /29 network address assigned as the default gateway.  From the 350 I can ping the internet without issue as long as the source isn't one of the 4 "gateways".  I can NOT ping outside the 350 from my PC getting an 172.16.15.10 address.  (it's gateway is the .1)
Can anyone help me with this?  I have no way of changing the config on the ASR.
2 Accepted Solutions
Giuseppe Larosa
Hello @pgreen ,
unfortunately , you would need the following :
on ASR 1001:
static routes for the 4 subnets on the switch with next-hop the switch IP address on their direct link
and changes to NAT on the ASR 1001 to make source NAT happens for hosts in those 4 IP subnets.
NAT is not supported on switches so your other option is to add a router on the path between switch and ASR that will do NAT for your 4 subnets.
Hope to help
Giuseppe
balaji.bandi
SG350x-48P  - is the switch does not do any NAT
all subnet need to be NAT on ASR - is this took place ?
You need to have device in between ASR and Switch does the NAT for you to work your expected setup.
BB
5 Replies 5
Giuseppe Larosa
Hello @pgreen ,
on ASR 1001:
Hope to help
Giuseppe
Thanks!
balaji.bandi
BB
Thanks for that.
Hello @pgreen ,
you should configure NAT/PAT on the SG350 for all 4 vlans that have 172.16.15.x IP addresses (inside) to the IP address you are using on the interface connecting to ASR1001.
Regards, LG
*** Please Rate All Helpful Responses ***
