sh command info
ud0508500
Is there a command to view a PVC that has been built by a provider (AT&T) on the HUB side ATM Router? do not know if this is possible, but wanted some advice..
paolo bevilacqua
Unfortunately there's no command because the ILMI protocol does not carry PVC status like FR does.
Thanks for the Help..appreciate the quick response paolo..
ud0508500
Thanks...appreciate the help!
