sh ip cache verbose flow when vrf is enabled
nikhilnaidu
i am looking for QoS markings on one of the vrf's. normally we can use the command sh ip cache verbose flow and it would list out all the flows and the markings. but on a router with vrf enabled the command shows no output. how do i see the flows and markings on a router where vrf is enabled using ip cache verbose flow?
#sh ip cache verbose flow
IP packet size distribution (0 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
IP Flow Switching Cache, 0 bytes
0 active, 0 inactive, 0 added
0 ager polls, 0 flow alloc failures
Active flows timeout in 30 minutes
Inactive flows timeout in 15 seconds
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
SrcIf SrcIPaddress DstIf DstIPaddress Pr TOS Flgs Pkts
Port Msk AS Port Msk AS NextHop B/Pk Active
a.alekseev
Level 7
Level 7
show the configuration.
