Shape sustained burst (bc) cannot be configured this interface
Hi, Im trying to apply something like this in interface "GigabitEthernet over SIP-400:
class-map match-all SHAPING
match any
policy-map SHAPE-1000
class SHAPING
shape average 1000000000 10000000 0
but is no possible because the BC...
"Shape sustained burst (bc) cannot be configured this interface"
there is another way to apply the policy map? The router is a 7604.
Thanks in advance.
Laurent Aubert
Configuring Bc value is not supported on the SIP-400. You need to let the router calculate it for you (do not enter any value).
Laurent.
Hi Laurent, humm dont work on the SIP-400, but I also have GLCs... 2 ports at GigaEthernet, if I apply do them dont work also :) is normal?
Thanks one more time.
fzamora
Changing Bc is not supported on sip-400 shaping. If you want to control
buffering you can configure queue-limit on the shaping class.
Franco
Thanks for your answer.
The Link is 1Gb, can I apply:
match any
class SHAPING
bandwith 1000
queue-limit 10
10 for queue-limit is ok?
Thanks in advance.
