Shaping vs. Policing
chris.notley
   police rate 400000
     exceed-action drop
Hi there,
I have been trying to configure shaping with minimal success on a router with a ADSL/dialer interface.  I am trying to reserve a certain amount of bandwidth for certain traffic types (defined by an ACL).  I initially started using policing as per below (the 100Kbps was initially just used for testing):
class-map match-any CLASS-HIGH
match access-group 2000
policy-map QOS-DEFAULT
class CLASS-HIGH
    priority 150
class class-default
    police rate 100000
      exceed-action drop
interface Dialer10
service-policy output QOS-DEFAULT
This worked - traffic other than that defined in ACL 2000 was capped at 100kbps.  I then tried changing the class-default configuration from police to shape as follows:
class CLASS-HIGH
    priority 150
class class-default
   shape average 100000
This appeared not to buffer any traffic - running the command 'show policy-map interface dialer 10' after 10-15 minutes showed the following:
Dialer10
  Service-policy output: QOS-DEFAULT
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
    Class-map: CLASS-HIGH (match-any)
      191 packets, 25612 bytes
      5 minute offered rate 1000 bps, drop rate 0 bps
      Match: access-group 2000
        5 minute rate 1000 bps
      Priority: 150 kbps, burst bytes 3750, b/w exceed drops: 0
    Class-map: class-default (match-any)
      20639 packets, 29885658 bytes
      5 minute offered rate 557000 bps, drop rate 0 bps
      Match: any
      Queueing
      shape (average) cir 100000, bc 2500, be 2500
      target shape rate 100000
I am sure I am just missing really obvious - having looked through various cisco articles and posts here, I thought I could use shaping to restrict the rate of an interface...
Any feedback would be appreciated.
Chris
12 Replies 12
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
I believe the "offered rate" is the ingress rate seen by the class, not the same as the egress rate.
What your corresponding stats look like for overall egress rate on the physical interface?
Hi both,
Thanks for your responses.  I've now switched back to policing and didn't gather the atm stats before.  I will kick it off again shortly and respond here.
In regard to Olivier's statement regarding 'traffic to the dialer before the shaping'; this makes sense, but given that the rate is significantly higher than the targeted shaped rate, would I not expect to see some indication of queuing?  I kicked off an rsync job each time I amended the configuration, which is not matched by ACL 2000, hence it should be being shaped?
On the one hand, I know the policing is working, I'm just a little bugged as to why shaping just doesn't seem to happen at all.
Chris
load-interval 30 on the dialer 10.
(you're looking stats over last 5 min)
zheng.olivier
the offered rate is the data rate in input of the policy map. In your case, there are 557kbps traffic to the dialer before the shapping.
Hi again,
So I've re-applied the shaping policy and added the load interval as suggested.  I've pasted below the relevant section (as well as including the details of the high priority ACL for reference) below:
class CLASS-HIGH
    priority 150
class class-default
access-list 2000 remark *** VOIP TRAFFIC ***
access-list 2000 permit udp host 1.2.3.4 any eq 4569
access-list 2000 permit udp host 1.2.3.4 any eq 5060
access-list 2000 permit udp host 1.2.3.4 range 18000 18999 any
interface Dialer10
load-interval 30
I then kicked off an rsync session (uploading traffic through the dialer interface) and after approx five minutes ran the command 'show policy-map interface dialer 10', the output of which is below:
Dialer10
      228 packets, 28806 bytes
      30 second offered rate 0 bps, drop rate 0 bps
        30 second rate 0 bps
      14047 packets, 19312173 bytes
      30 second offered rate 862000 bps, drop rate 0 bps
      Match: any
      Queueing
Immeditately afterwards I ran the command 'show interface atm 0/0/0', the output of which is pasted below:
ATM0/0/0 is up, line protocol is up
  Hardware is HWIC-DSLSAR (with Alcatel ADSL Module), address is 0026.9957.4514 (bia 0026.9957.4514)
  MTU 4470 bytes, sub MTU 4470, BW 956 Kbit/sec, DLY 530 usec,
     reliability 255/255, txload 227/255, rxload 6/255
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  23 maximum active VCs, 256 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input never, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 65602
  Queueing strategy: Per VC Queueing
  30 second input rate 23000 bits/sec, 46 packets/sec
  30 second output rate 854000 bits/sec, 75 packets/sec
     32530116 packets input, 1280223521 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 7808 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     34688778 packets output, 366613440 bytes, 0 underruns
     3 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
This seemed to confirm my feeling that the shaping was not taking effect, but to verify I then reverted to a policing from shaping, as per the following:
class CLASS-HIGH
    priority 150
class class-default
   police rate 100000
     exceed-action drop
I then kicked off the same rsync session again and after a few minutes ran the command 'show policy-map interface dialer 10', the output of which is below:
Dialer10
      341 packets, 42030 bytes
      4473 packets, 5150577 bytes
      30 second offered rate 210000 bps, drop rate 134000 bps
      Match: any
      police:
          rate 100000 bps, burst 3125 bytes
        conformed 2255 packets, 1916405 bytes; actions:
          transmit
        exceeded 2213 packets, 3233948 bytes; actions:
          drop
        conformed 75000 bps, exceed 134000 bps
The output of 'show interface atm 0/0/0' gave the following:
     reliability 255/255, txload 21/255, rxload 1/255
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 66363
  30 second input rate 5000 bits/sec, 8 packets/sec
  30 second output rate 79000 bits/sec, 8 packets/sec
     32567786 packets input, 1283867072 bytes, 0 no buffer
     34746716 packets output, 444394311 bytes, 0 underruns
Thanks again for your help!!
Chris
Disclaimer
Posting
From you stats, it does appear the shaper isn't engaging.
If you have maintenance, you might open a case with TAC.
Apply your policy map directly to the ATM 0/0/0 interface :
interface atm 0/0/0
pvc ...
service output QOS-DEFAULT
Hi Olivier,
Thanks again for the quick response!
I initially applied the policy under the PVC as you suggested - config as below:
class CLASS-HIGH
    priority 150
class class-default
interface ATM0/0/0
load-interval 30
pvc 0/38
  dialer pool-member 10
  service-policy out QOS-DEFAULT
I then kicked off the rsync again and saw the following interface stats after approx 5 minutes:
     reliability 255/255, txload 227/255, rxload 11/255
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 67198
  30 second input rate 43000 bits/sec, 56 packets/sec
  30 second output rate 852000 bits/sec, 78 packets/sec
     32770209 packets input, 1298909685 bytes, 0 no buffer
     0 input errors, 7809 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     34970345 packets output, 754963270 bytes, 0 underruns
One interesting anomoly is that I noticed the 'service-policy out QOS-DEFAULT' dissapeared from the pvc instance after a few minutes.  I'm able to repeat this consistently (add the service policy, verify it's set and then see it dissapear shortly afterwards).
I then tried applying the service policy above the pvc as follows:
interface ATM0/0/0
load-interval 30
pvc 0/38
Again, after kicking off the rsync and waiting a few minutes I saw the following interface stats:
     reliability 255/255, txload 149/255, rxload 8/255
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 69550
  30 second input rate 31000 bits/sec, 37 packets/sec
  30 second output rate 562000 bits/sec, 60 packets/sec
     32897715 packets input, 1400723976 bytes, 0 no buffer
     0 input errors, 7843 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     35097602 packets output, 828523368 bytes, 0 underruns
And the following after running 'show policy-map interface atm 0/0/0':
ATM0/0/0
      1410 packets, 205532 bytes
      30 second offered rate 5000 bps, drop rate 0 bps
        30 second rate 5000 bps
      Priority: 150 kbps, burst bytes 4470, b/w exceed drops: 0
      75547 packets, 20414726 bytes
      30 second offered rate 891000 bps, drop rate 0 bps
      Match: any
      Queueing
Cheers,
Chris
Sorry for the late answer this time (in production, you can have time to post and 5 min after, there is a rush).
"However, the same policy is accepted on an ATM VC since the VC supports native ATM-layer shaping via the vbr-nrt, vbr-rt, cbr or abrcommands.
7200-16(config)#int atm 5/0.20
7200-16(config-subif)#pvc 1/50
7200-16(config-if-atm-vc)#vbr-nrt 100 100 94
7200-16(config-if-atm-vc)#service-policy output queuenoshape
7200-16(config-if-atm-vc)#end
7200-16#show policy-map int atm 5/0.20
 ATM5/0.20: VC 1/50 -
Thanks again Olivier!
I've not used native ATM-layer shaping before - maybe I'm misreading this, but won't this affect all traffic passing through the interface?  My goal here is to stop general traffic bursting up to the maximum.
Have I misunderstood?
Chris
It will affect all the traffic, but it'll use the service policy output to shape. So if you have defined the traffic class CLASS-HIGH, the priority reserved for that is still there.
Ex: you have a 2M link, you want to shape to 2M, but with 150k for AF41 class:
- you put the vbr nrt with the values corresponding to 2M.
- in the output policy, you set your AF41 class, and you set the class-default with remaining bandwidth
Tell me if we're lost in translation.
Hi Olivier,
Thanks again - I will give it a try!
Chris
