Shared networks across datacenters for migration
Dan Pride
I am currently planning a new datacenter and all that entails. This new datacenter is in the same city and is less than 2ms latency. The old datacenter and new datacenter will be connected with a VPLS circuit terminated on CISCO 4431 ISRs. The datacenter use Vmware and all machines need to be vmotioned to the new datacenter.
Each datacenter has a pair of Nexus 9K switches hosting the layer 3 datacenter networks configured with HSRP at each site
HSRP requires layer 2 connectivity to properly share the HSRP packets. Since the VPLS is terminated on an ISR, the packets do not flow between the 2 sites and they do not share a floating IP.
Is there a method to setup a HSRP style network between these 2 datacenters to allow easy migration without giving new IPs to the workloads?
Giuseppe Larosa
Hello @Dan Pride ,
The ISR 4431 are not powerful enough terminate the VPLS circuits directly on the Nexus devices on the two sites or you will have a bottle neck for performance.
Hope to help
Giuseppe
balaji.bandi
i would prefer any ASR 1K is good for VPLS rather ISR.
BB
