Shared Port Adapters and line card difference
Anwar Safian
Hi expert
I would like to know what is the difference between Shared Port Adapters and line card? Why Cisco name it difference?
balaji.bandi
Not sure what you referring here,
ASR support Line Cards, also Voice/Data port adapter here
https://www.cisco.com/c/dam/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/qa_c67-443169.pdf
https://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/datasheet-c78-731632.html
if this not what you referencing, give us the part number to suggest better here,
BB
Hi Balaji
Thanks for your reply.
Is Shared Port Adapters and line card refer to same thing?
If same, why for example, Cat9400, we dont have Shared Port Adapters term, but only line card term
Do not confuse yourself between the models, Line card is Line card.
ASR is different compare to Catalyst
Catalyst have Line card and modules. no SPA support.
BB
Leo Laohoo
Because a line card and an SPA are different.
SPA (Shared Port Adapter) is an adapter that "branches" out a slot and "inside" an SPA can have different line cards inside.
An SPA is "passive" (doesn't require power):  It is a "tray" to put different line cards in it.
