SHDSL compatibility
a.hajhamad
Level 4
Level 4
I'm preapring a design that use SHDSL technology, i will order HWIC-2SHDSL and HWIC-4SHDSL, our provider using Lucent Stingers FS+ 72-ports, Annex A.
Doest the above mentioned cards are supported for these DSLAMs?
And i have another question, If supported, i will order the HWIC-4SHDSL 4 wires, and get bandwidth upto 4 Mbps (512, 1MB or anything else), right?
Thanks in advance
Abd Alqader
mohammedmahmoud
Level 11
Level 11
Hi Abd Alqader,
Yes they are compatible, and note that you can have up to 2M on a single pair:
http://www.cisco.com/en/US/products/ps5949/products_data_sheet0900aecd80581fa0.html
HTH,
Mohammed Mahmoud.
