NAT problem to two physical links to two ISPs
oj88
I have a 'simple' dual-homed ISP using two default-routes. Here's the sample config:
int s0
ip add 1.1.1.1 255.255.255.252
ip nat outside
int s0
ip add 2.2.2.1 255.255.255.252
ip nat outside
int f0
ip add 192.168.1.1 255.255.255.0
ip nat inside
ip nat pool isp1 1.1.1.1 1.1.1.1 netmask 255.255.255.252
ip nat pool isp2 2.2.2.1 2.2.2.1 netmask 255.255.255.252
ip nat inside source list LAN pool isp1 overload
ip nat inside source list LAN_ pool isp2 overload
ip access-list standard LAN
permit 192.168.1.0 0.0.0.255
ip access-list standard LAN_
ip route 0.0.0.0 0.0.0.0 1.1.1.2
ip route 0.0.0.0 0.0.0.0 2.2.2.2
end
Using the config above, outbound traffic gets load-shared between the two ISPs if both links are up, which is desireable. But if we were to simulate a failure on ISP1 (ie. put Serial0 in admin down), the LAN users gets disconnected and will not use ISP2 unless we remove the ip nat entry for the ISP1. What am I missing?
All the end user wanted is the ability to load-balance between their two ISPs and failover to the other ISP if one fails.
respe
here's a working config
conf t
int s0
ip add 1.1.x.x.255.255.252
ip nat outside
int s1
ip add 2.2.x.x.255.255.252
ip nat outside
int f0
ip nat inside
ip nat inside source route-map ISP1 pool isp1 overload
ip nat inside source route-map ISP2 pool isp2 overload
route-map ISP1
match ip address LAN
match interface S0
route-map ISP2
match interface S1
end
Hi Roel
The config posted by you takes care of loadbalancing of the outgoing traffic which gets out of this customer LAN but in case of the incoming traffic to the customer network i dont think you have much control or you can expect the same kinda even balancing on the traffic is possible...
Though i havent tried this setup in a live scenario pls do let me know whether this has been implemented and have better performance with this kinda setup.
regds
