Transport input all
mohammedmahmoud
Level 11
Level 11
all,
I've got some problems understanding "transport input all" configured on a tty line (which i need to configure once on my Access Server and once on my clients routers):
-Does it enable all IP protocols ?
-Does it allow only one way traffic (modem --> router), do i need "trasport output all" to allow the other direction traffic (router--> modem) ?
-If i make it "transport input telnet", whould that only enable telnet access or any other protocols ?
Thanks in advance.
Hello Mohammed,
´transport input all´ would allow the following protocols for inbound connections to your router:
lat | mop | nasi | pad | rlogin | ssh | telnet | v120
For outbound connections, you indeed need the ´transport output´ command, and then specify the protocols required.
´transport input telnet´ would only allow telnet connections nbound.
Have a look at the relevant command references:
transport input
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/dial_r/drprt1/drtermop.htm#6014
transport output
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/dial_r/drprt1/drtermop.htm#5430
HTH,
GP
Thanks for your reply, but i've got the following concerns:
1st-When i took a look at the command reference it said:
"telnet Specifies all types of incoming TCP/IP connections. "
Does this mean any IP traffic ? (do i have to do this to allow ppp over the modem ?)
2nd-Does this mean that if i used the router to telnet to the modem --> i'll need "transport output all" and vice versa (to telnet from the modem to the router i'll need "transport input all")?
Thanks in advance.
