SHDSL line aggregation
Vijendra Ramdoo
Hello people,
Thanks to give your insights on below.
I have a client who has 2 point to point links between 2 sites.
The point to point links are of type SHDSL from two different service providers.
A ---------------------  B (ISP 1)
A ---------------------  B (ISP 2)
Is there some load balancing or aggregation that can be done on these 2 links. Client would prefer not using one line only for backup.
Thanks to point me in the right direction.
Vijen
Hello you dont say what routing you are using dyanmic or static?
However you with static you can basically use two default routes:
ip route 0.0.0.0 0.0.0.0 isp1
ip route 0.0.0.0 0.0.0.0 isp2
Dyanmic routing you can also load share but it all depends what routing protocol you are using?
res paul
Kind Regards
Paul
