Can Cisco 3850 be worked as a Wireless Controller
Ninad Thakare
I have Cisco 3850 switch and 4 no. of. Cisco 3602E AIRCAP AP.
Can I use 3850 as WLC. If so how can I..? Is there any reference guide for it. I tried, but didnt found anyting.
here are some switch details for reference.
SW#sh flash:
-#- --length-- ---------date/time--------- path
  2    2097152 Feb 19 2014 10:45:48.0000000000 +00:00 nvram_config
  3   79113792 Jan 23 2014 03:13:53.0000000000 +00:00 cat3k_caa-base.SPA.03.03.01SE.pkg
  4    6476476 Jan 23 2014 03:13:54.0000000000 +00:00 cat3k_caa-drivers.SPA.03.03.01SE.pkg
  5   34503664 Jan 23 2014 03:13:53.0000000000 +00:00 cat3k_caa-infra.SPA.03.03.01SE.pkg
  6   34788684 Jan 23 2014 03:13:54.0000000000 +00:00 cat3k_caa-iosd-universalk9.SPA.150-1.EZ1.pkg
  7   25009040 Jan 23 2014 03:13:53.0000000000 +00:00 cat3k_caa-platform.SPA.03.03.01SE.pkg
  8   77296448 Jan 23 2014 03:13:54.0000000000 +00:00 cat3k_caa-wcm.SPA.10.1.110.0.pkg
  9       1248 Jan 23 2014 03:14:05.0000000000 +00:00 packages.conf
10       1216 Feb 18 2014 22:32:04.0000000000 +00:00 vlan.dat
1277546496 bytes available (262029312 bytes used)
SW#sh version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.01SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 05-Dec-13 10:15 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
CRSPUN uptime is 1 day, 51 minutes
Uptime for this control processor is 1 day, 56 minutes
System returned to ROM by reload
System restarted at 16:35:43 UTC Tue Feb 18 2014
System image file is "flash:packages.conf"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipservices
License Type: Permanent
Next reload license Level: Ipservices
cisco WS-C3850-24P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOC1749X18T
12 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
250456K bytes of Crash Files at crashinfo-2:.
1609272K bytes of Flash at flash:.
1609272K bytes of Flash at flash-2:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of  at webui:.
Base Ethernet MAC Address          :
Motherboard Assembly Number        : 73-14441-06
Motherboard Serial Number          :
Model Revision Number              : K0
Motherboard Revision Number        : C0
Model Number                       : WS-C3850-24P
System Serial Number               :
Switch Ports Model              SW Version        SW Image              Mode
*    1 32    WS-C3850-24P       03.03.01SE        cat3k_caa-universalk9 INSTALL
     2 32    WS-C3850-24P       03.03.01SE        cat3k_caa-universalk9 INSTALL
Switch 02
Switch uptime                      : 1 day, 56 minutes
Configuration register is 0x102
Vidyadhar Evani
You can fine details in this link http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/deployment_guide_c07-727067.html
Pls. note that you need to have AP License in order to run C3850 as MC (Mobility Controller ). If you have an existing 5508 or WiSM controller you can transfer or use them as MC and C3850 as MA.
Sample Mobilty controller configuration :-
wireless management interface Vlan10
ap cdp
Wireless mobility controller
Sample Mobility Agent configuration :-
wireless mobility controller ip 10.10.10.10 public-ip 10.10.10.10
ap cdp
ap dot11 24ghz shutdown
ap dot11 5ghz shutdown
ap country <XX> ( Country Code list : Norway : NO, London : GB, China: CN, Singapore: SG, United States: US)
no ap dot11 24ghz shutdown
                      no ap dot11 5ghz shutdown
Hope this helps !!
Cheers,
Vidy
/Vidya
