SHDSL over ATM
net buzz
Hi!
I have a Cisco 3825 router situated at the main site. It is equipped with a 1 VWIC2-1MFT-T1/E1 card and 1 AIM- ATM-1T1/E1 card.
There are several Cisco 2811 each equipped with a WIC-1SHDSL-V3 card. I need to connect these Cisco 2811 using SHDSL as communication technology. The SHDSL lines will terminate on the ATM link.
What is the configuration for the ATM card on the Cisco 3825 router?
Please see attached the topology and the router configs.
Alvin
net buzz
Please find attached the topology.
Alvin
paolo bevilacqua
Recommend you engage a reputable consultant or certifies cisco partner to make this configuration for you.
