03-30-2007 11:53 AM - edited 03-03-2019 04:21 PM
I cannot seem to find a part number for a rack kit for the 1841 router, I would like to get the Gen kit that is a shelf kit. Can you get me the part number?
Solved! Go to Solution.
03-30-2007 12:16 PM
Mark
I found this set of Q&A about rack mount for the 1841:
Q. Is the Cisco 1841 rack-mountable?
A. The Cisco 1841 is now rack-mountable. In order to enable the rack-mount functionality, the optional Cisco 1841 rack-mount kit (ACS-1841-19-RM=) needs to be used.
Q. When was the rack-mount capability introduced on the Cisco 1841?
A. All Cisco 1841 chassis shipping since Q4FY06 are rack-mountable. Cisco 1841 chassis with the following starting serial numbers have the rack-mount screw holes: FTX1009W0Z3 (United States), FCZ100812UR (Europe, Middle East, and Africa), and FHK100653JL (Asia Pacific).
Q. Are all Cisco 1841 chassis rack-mountable?
A. All Cisco 1841 chassis shipping since Q4FY06 are rack-mountable. Please refer to the serial numbers provided above to find out whether a specific chassis has the rack-mount screw holes to be rack-mountable with the optional rack-mount kit. All chassis currently shipping are rack-mountable with the optional Cisco 1841 rack-mount kit.
it was at this URL:
http://www.cisco.com/en/US/products/ps5853/products_qanda_item0900aecd80181208.shtml
Rick
03-30-2007 12:16 PM
should be ACS-1800-RM-19=
Hope this helps, please rate all useful posts!
03-30-2007 12:16 PM
Mark
it was at this URL:
Rick
