Should I use QOS for replicating over a vital link?
Mark Mattix
Level 2
Level 2
My company is planning to install remote disaster recovery equipment which will receive a replication from our primary. I don't have much experience with VMware but I was exploring and I found that under the performance tab of VCenter it looks like Vranger is using up to 70000 KBps (70 megabytes a second) on the link that's currently directly connected from our primary to DR.
What would you suggest I do with a DR that could peak at 70MByte a second and hold steady at 25MByte a second over a 30Mbit ( 3.5 Megabytes a second) internet link? This link is vital and all users need access to it. Would QOS be ideal, a dedicated line or is this just impossible with all this data throughput?
Thanks for any advice!  -Mark
SOcchiogrosso
Level 4
Level 4
As a best practice replication traffic should be isolated on its own link. If replication traffic is going to occur on the normal links that user traffic exists on than QoS should be implemented to protect the normal traffic being being drowned out by the constant replication traffic.
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
My inclination would be to use QoS.
SOcchiogrosso
Level 4
Level 4
