show dmvpn, ip nhrp redirect and ip nhrp shortcut
JustasP
Hello. I seem to be having issues with my DMVPN configuration not being able to be set to phase 3.
I am unable to execute the commands "ip nhrp redirect" on my hub router and "ip nhrp shortcut" on my spokes. Also, the terminal doesn't seem to recognize the command "show dmvpn". Below are the configurations for my router and one of the spokes. What could be the issue?
My HUB router:
version 12.4
hostname R1_hub
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip tcp synwait-time 5
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set MYSET esp-aes esp-sha-hmac
crypto ipsec profile PROFILE
set transform-set MYSET
interface Loopback0
ip address 10.1.0.1 255.255.255.0
interface Tunnel0
bandwidth 1000
ip address 10.123.0.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 1
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 5
ip tcp adjust-mss 1360
no ip split-horizon eigrp 1
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 6
tunnel protection ipsec profile PROFILE
interface FastEthernet0/0
ip address 23.0.0.1 255.255.255.0
duplex half
interface FastEthernet1/0
no ip address
shutdown
duplex half
interface FastEthernet2/0
no ip address
shutdown
duplex half
router eigrp 1
network 10.0.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 23.0.0.5
ip route 10.1.0.0 255.255.255.0 Loopback0
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
My spoke router:
version 12.4
hostname R2_spoke
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
encr aes
group 2
interface Loopback0
ip address 10.2.0.2 255.255.255.0
interface Tunnel0
bandwidth 1000
ip address 10.123.0.2 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast 23.0.0.1
ip nhrp map 10.123.0.1 23.0.0.1
ip nhrp nhs 10.123.0.1
tunnel key 6
ip address 42.0.0.89 255.255.255.0
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
router eigrp 1
network 10.0.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 42.0.0.5
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
balaji.bandi
what is the error getting when you try to add that command ?
show version will help also look feature navigator of IOS - its been Long i have works 12.X  code.
For best DMVPN functionality, it is recommended that you run the latest Cisco IOS software Release 12.4 mainline,12.4T, or 12.2(18)SXF.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_conn_dmvpn/configuration/12-4t/sec-conn-dmvpn-12-4t-book/sec-conn-dmvpn-dmvpn.html
feature navigator :
https://cfnng.cisco.com/
BB
