Show DSL Interface ATM x/x/x/ Question
stevennowell
The crc errors presented by this command appear to be set to some sliding time frame. Does anyone have an idea as to the timeframe that is utilized? A clear counters does not clear these error stats, btw. I cant locate this info anywhere. Also does anyone have an idea of an acceptable noise margin? Thanks!!
router>sh dsl int atm 0/0/0
ATM0/0/0
Alcatel 20150 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: 'ALCB' 'BDCM'
Vendor Specific: 0x0000 0x544D
Vendor Country: 0x00 0xB5
Capacity Used: 96% 97%
Noise Margin: 8.0 dB 6.0 dB
Output Power: 20.0 dBm 11.5 dBm
Attenuation: 32.5 dB 19.0 dB
Defect Status: None None
Last Fail Code: Handshake or init message invalid or had bad CRC
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 2722 (0 spurious)
PHY Access Err: 0
Activations: 10
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: embedded
Operation FW: embedded
SW Version: 3.8131
FW Version: 0x1A04
Interleave Fast Interleave Fast
Speed (kbps): 1408 0 512 0
Cells: 455 0 1160908 0
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 19 0
Header Errors: 0 0 5 0
Bit Errors: 0 0
BER Valid sec: 0 0
BER Invalid sec: 0 0
americain
Hello
I don't understand why you want to know the timeframe? Or is it pure intrest? Just a joke but i can help you in a other way.
The answer lies in your last line in the post.
If the noise margin and the used capacity would show better values the CRC errors will disapear.
A good noise margin is higher than 10dB and the used capacity should be lower than 80 to 85%.
Also the adsl speed values seem strange, the downloadspeed is 1408 kbit. This doesn't look like a regular adsl speed/profile? The uploadspeed 512kbs looks ok.
I think you should check the cabling or the adsl filter, when it is used of course.
Hope this will help you.
Greetings
Frederic
Hello
Did you solve the problem?
Any feedback?
Greetings
